Question about RTO Automatic Transmission And Engine Oil Pressure Tester
Volvo 240 transmission problem
My car don't want to change to the 4th speed. I change the OD relay and solenoid. I change the filter and the oil. The wiring and the button are ok. What else I can check
    New Friend:
  • 52 Answers
Get your ride checked for error code and know the exact cause of problem i.e. either faulty Transmission Control Module (TCM) or Low reading for clutch pack. Also it may be possible that the fourth gear's teeth may have been damaged. Let a professional inspect the ride and know where the fault is.
Posted on Jul 23, 2013
88 volvo 240 dl won't shift into 4th
This is common to the AW70 transmission when the rear bushing has been left very worn for a period of time. The rear shaft wear heavily on the main transmission housing causing the pressure not to build enough to engage the overdrive gear.
Apr 21, 2014 | 1988 Volvo 240
Fuel pump volvo 240
have you changed the fuel filter?
Jul 06, 2013 | Cars & Trucks
My 93 Vovlo wagon overdrive is the issue. It's not the relay which everyone keeps suggesting, that has been replaced and tested. Worked for a week and is now blowing fuse # 11. I believe I have a wiring...
The most common problem that these cars have is the wire to the solenoid. The insulation will come off of the wire and it will touch the rear of the transmission. It is a bit of a pain to get to the wire to repair it if you don't have a lift.
Apr 19, 2011 | 1993 Volvo 240
Where do i find the overdrive solenoid in a 1991 volvo 240?
The overdrive solenoid is connected to the transmission itself on this Volvo. You will find the switch on the passenger side of the transmission. It looks like this
As a means of testing operation of the solenoid - you can ground out this switch by turning the key in the ignition into the on position. Make sure engine is off and the transmission in 4th gear and listen for the click of the soleniod on the back of the overdrive. Also the light on the dash should iluminate as well.
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 10, 2009 | Volvo 240 Cars & Trucks
1992 240 Volvo automatic transmission won't shift out of 3rd gear
Check the transmission filter, may be clogged up, do not change the oil, keep the same oil when replacing filter, trust me to avoid transmission repair.
Jul 09, 2009 | 1991 Volvo 240
940 volvo comes out of overdrive without touching button
IPDusa.com.  If its similar to a 240 (and it most likely is) you can purchase a block off plate for the solenoid so you won't lose 4th gear (actually its OD from torque converter lockup).
http://www.ipdusa.com/Volvo-940960/Transmission-&-Drive-Train/Automatic-Transmission/Automatic-Over-Drive-Solenoid-Bypass-Kit/p-136-278-676-1031/
Apr 21, 2009 | 1993 Volvo 940
1992 volvo 240 gl auto-transmission upshift`s through 3`d gear,
Check your fuses,then replace the overdrive relay,if not this,they sale an bypass plate from IPB,for about 40 bucks,very easy to install.
Apr 02, 2009 | 1992 Volvo 240
Need a schematic for OD relay/switch 95 volvo 940
Check speesensor at transmission.Have somebody scan it.
Jan 05, 2009 | 1994 Volvo 940
Stuck in overdrive
Overdrive relay usually fixes the problem. With the engine idling quietly, press the OD switch on the shift lever. Do you hear a click? If not, it is probably the relay. Located behind the glove box, passenger side. toward the center console. Pick up a used one on Ebay ( about $10 bucks) and swap it out. Cured my problem right away. Be sure you change the correct relay because Volvo hides several back there. I would buy the spare, then match it with the one now installed. If not the relay, you will need a new solenoid in the transmission. About $200 installed.
Nov 03, 2008 | 1993 Volvo 240
Volvo 240 GL Transmission
You have an overdrive relay issue. The tansmission is really a four-speed box, but the OD selector either locks our fourth gear or allows the car to shift normally into fourth. I use the OD on my volvo all the time, because the revs drop in half when the OD is activated, The relay is located behind the glove box, toward the center console. $10 buck on Ebay and your transmission should shift correctly again. I would try that BEFORE more expensive fixes, like OD solenoid $200 or transmission control module. Just for kicks a picked up a spare ECU on Ebay for $10 because these get costly if and when they go. Easy fix, though, a couple of plugs.
Jun 12, 2008 | 1989 Volvo 240
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
53 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
