Cabrio wtw5700x My washer is leaking water every time I wash clothes. Its not from the hose. I know its from the washer. Will it be hard for myself to fix?
  • Washing Mach... Master
  • 744 Answers
Try looking for a hole in the door seal
this video might help you change the seal
Posted on Jul 22, 2013
  • 125 Answers
SOURCE: Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Posted on Jan 09, 2008
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
SOURCE: Whirlpool Cabrio Leaks Water
you probably got coins or junk in the water pump on the bottom back of washer and it poked a hole in the housing. Thats what happened to me
Posted on Sep 16, 2008
onthejob5130
  • 640 Answers
SOURCE: LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Posted on Dec 25, 2008
SOURCE: washer leaking
Check for cracks and corrosion on the outer tub. Water might be leaking from there. Please do comment. Good luck.
Posted on Jan 09, 2009
How to fix NEC NW-961 6kg
Good to know the washer is working fine.
You may also benefit from running the washer empty with a cleaning agent like this
http://www.rubbedin.com.au/Product/17/The-Magic-Range/Washing-Machine-Cleaner-
Apr 27, 2014 | Washing Machines
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer displays F1 and you have to pause and restart several times before it will start then stops after awhile and must repeat same process is there a way to fix this without calling a repairman
check the hose make sure its not clogged,if you can remove clothes,and pour 1/2 c bleach and let it stand for about 1-2hrs. and the run by it self through heavy-duty cycle no clothes hot water,see if this works and is drain hose at a 90degree to drain pipe?try this let me know
Jul 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
Jun 11, 2010 | GE WBSR3140DW Top Load Washer
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
It is leaking from the bottom during the wash cycle. What is going on?
If you mean its leaking anytime you have water in the drum,the first thing to check is the drain hose connection at the back of the washer,You'll want to do this with the washer pulled out,(don't let the drain hose drop below the water level or you'll have a mess)If its not leaking there you should be able to look under the washer & see which connection it is(usually the inlet to the pump) Might be as simple as tightening the hose clamps.Hope this helps
Jan 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My roper wash machine is leaking. is it worth
check when it's leaking during the cycle.
If the fill hose has become unhooked from the outer drum of the machine, it'll just dump water all over the floor... it'll leak out of the case of the machine, but it's an easy fix... you simply open the machine, reinstall the hose into the drum or you may have to replace the hose...washing machines will last a good long time...it's worth the trouble to fix...let me know if you need help opening it up.
This can happen if the machine is overloaded... I had a laundromat and this happened alot because people were cheeeeep and wanted to overstuff the machine thinking they'd get a better deal...not true...dirtier clothes and broken machines....
Aug 05, 2009 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
