Question about VR3 CD PLAYER MP3 WMA RDS CAR STEREO RECEIVER 220FD - VRCD220FD
Installing vr3 stereo in chevy cavalier
I have it connected directly to battery thru the firewall now it wont shut off, where do connect the power source so it acts as factory stereo and shuts off
  • 343 Answers
You need to cnnect it to a swicthed power source. They are located on the fuse bank, look for the radio fuse and tap off of that. It will not power off with the key if it is connected directly to the batery. It will however power off if it is connected to a key switched source.
Posted on Oct 19, 2013
Car wont start / no power
Turn your lights on. If they don't come on get a jump to start and check voltage at battery when running. It should read 14+V. If you have a charged battery, then the starter/starter connections as well as the battery connections should be checked and should be tight (no movement on the battery connections).
hope this helps.
Bill
Sep 28, 2016 | Metra 2006-2007 Chevy Monte Carlo Lt Car...
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
Where does the stereo fuse for Chevy Cavalier 2002 go
Four different sound systems were offered in the 2002 Cavalier. The basic power connection is the 10A RDO/INTLP FUSE in the I/P fuse block.
Sep 12, 2014 | 2002 Chevrolet Cavalier
I need to know the wire placements on a starter of a 1989 chevy cavalier
you have three post on the solenoid 2 big and 1 small 1 big connects directly to starter motor the other big gets direct battery power the little one is ignition (concidrably smaler wire) hope this helps be sure to double check all connections and grounds
Nov 17, 2010 | Chevrolet Chevy Cars & Trucks
I am istalling a jvc car stereo in my 92 chevy truck. The stereo wire connections have been cut. I was able to find the car stereo wiring schematic online. My problem is: when i turn the key to accesory...
hi this sounds like you have connected the permanent live wire to an auxiliary wire, ie, what ever the power source you have connected it to, only works until the vehicle has started, then the power is stopped, sorta like.. say, the starter motor, it only uses the power when it is needed then when it is running it shuts the power off, just like the lights on the dash ect ect, your best bet would be to find a permanent live from the battery supply...hope this helps
Jul 14, 2010 | Car Audio & Video
I need to know how to wire the power cables and other wires to the amp and then to the subwoofer plz can you help me nath
hey dennis if you have a standard car amplifier all you need to do is run a wire from the battery post straight from the battery to amp batt+ post, then negative side can also be run straight from battery negative, than the remote post on your amp. you can either utilize the power antenae circuit coming out of the stereo unit or an ignition power from your ignition power fuse box so you don't draw battery power when key is off, please reply back if your stereo unit has rca output and does your amp. have rca connection(rca connections are red and white audio cable style connection).
Sep 28, 2009 | Car Audio & Video
1995 Chevy G30 - No electricity at all, won't start.
I'm not familiar with your type of vehicle, but:-
Look for a 'fusible wire link' that may be down near the starter motor battry power connection cable. If fused, it will be melted.
Most vehicles hase either a fusible link or a high power fuse in between the battery output and the main vehicle distribution power bus.
Jul 09, 2009 | 1995 Chevrolet G20
1995 Z24 chevy cavalier wont even turn over...
obviously the altenator is running to earth inside ,could be a rectifier diode .change altenator and recharge battery
Apr 12, 2009 | 1998 Chevrolet Cavalier
Stereo amp power supply
No I wouldn't share the amp feed. It should be stand alone, with its own fuse.
Yes it is wise to connect directly to the battery, hence through the firewall.
You should purchase an amp wiring kit, matched to the
watts of the amp. It has everything you need to correctly make all of the connections.
Good luck
Aduz
Mar 11, 2009 | Car Audio & Video
I am installing an after market stereo deck into a 2004 Chevy Cavalier but I am not getting any power. From my research I need to hook the deck up to the vehicles ignition harness but I do not know where...
ok now this is fun i had a good ole time putting my after market raidio in on my 04 with out the $300 harness that the sterio shops wanna charge a arm and a leg to install you need to run your 12v power source to the igniton fuse its farly simple if you need picture diagrams i can deffianatly post some pictures showing you exactly how to wire it up bc trust me i was mad enuff trying to get my stereo in so i wouldnt mind helping some one else out on getting it installed bc its frustrating not knowing how to do it
Jul 19, 2008 | 2004 Chevrolet Cavalier
VR3 CD PLAYER MP3 WMA RDS CAR STEREO RECEIVER 220FD - VRCD220FD Logo
54 people viewed this question
Top VR3 Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a VR3 Audio Player and Recorder Expert? Answer questions, earn points and help others
