The Washing machine does not spray water through the rinse cycle machine is a LG model WFT755A
  • Washing Mach... Master
  • 744 Answers
If the drum is turning during rinse cycle and the lifting paddles are not broken you might have a pump problem if fitted with distribution pump
Posted on Jul 22, 2013
  • 1294 Answers
SOURCE: ge washing machine
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Posted on Sep 21, 2007
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
  • 166 Answers
SOURCE: lg washing machine gets stuck on the rinse cycle
Check and make sure the washer is draining properly, there is a drain catch at the bottom front of machine, twist and remove cap and clean out any debris you find. Also check and make sure your getting enough cold water to the unit. Also make sure your using HE detergent....If that fails you may have a bad control board.
Posted on Feb 24, 2010
Testimonial: "Thanks!!"
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
When washer goes into the rinse cycle it won't fill it contue to try and fill but won't
Check your manual. Some washers don't fill when they rinse, instead, they spray rinse. While the tub spins, they spray water in every few seconds until the cycle is completed. This is also how the second rinse works on a lot of models.
Dec 01, 2009 | Whirlpool Washing Machines
My hoover washing machine won't spray rinse or deep rinse on cold
Rinse cycles are normally with cold water only.
I believe you have a faulty cold water inlet valve. To confirm, put the machine on a cold only wash cycle, and see if it fill up with water.
If it does, then the valve is O.K. In that case the problem you are having with the rinse cycle is most likely a timmer fault.
Good Luck
Ash
Oct 23, 2009 | Hoover Washing Machines
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Jet spray nozzle not spraying water.
If no water is coming out at all, it might be that the inlet filter is clogged or the Est. time shows the code IE. To clean out the inlet filters, unplug the washer, turn off the water, open the valves, take a filter cap thing and try rinsing it out. To put it back to operational use, reverse the steps above.
Mar 26, 2008 | LG WM2688HWM TROMM SteamWasher
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
