Question about Royal Sovereign White 1200 BTU/12,500 Heating Air Conditioner
Water leaking in the inside of home.
They both leak water inside the house have to have a bucket to collect water so in does not ruin my hard wood floors please tell me why its has leak from day one
  • Royal Sovereign Master
  • 16,181 Answers
Air conditioners take the moisture out of the air. When the air passes through the coils on the evaporator, they are cold. This causes the air to condense and water to form on the coils. It then drips off into a pan. When the pan is full if it is not drained, you will have an overflow and things get wet. How much water the unit collects depends on how much humidity is in the air, how much air you are moving through the coils and the temp of the coils.
Posted on Jul 22, 2013
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
My DDR7009REE HAS WORKED GREAT FOR A MONTH. BUT NOW IT LEAKES ON THE BASEMENT FLOOR. I SHUT IT OFF FOR 2 DAYS THINKING IT MAY HAVE FROZE UP. TURNED IT BACK ON AND IT LEAKS ON THE BASEMENT FLOOR INTEAD OF...
dehums remove humidity from air inside unit the evaporator sits in drain pan , drain pan has some sort of line or tube witch leeds to the internal collection or bucket thats what you slide out and empty when its full , ther is some sort of sensor or float switch that lets you know wen full make sure unit is draining properly inernaly and full system is working properly
Jul 03, 2011 | Danby DDR7009REE Dehumidifier
My dehumidifier is only a couple months old and is leaking water all over the floor while collecting in the bucket too. Why and how can I fix it? - I will take it back under warranty but would rather just...
The leaking problem usually happens for 2 reasons,
1. If your unit is equipped with a float valve inside the top of the water collection bucket, it's stuck in
the UP position. Turn the unit OFF and unplug for the wall outlet. Remove and empty the bucket
if necessary. Look at the foam ball on the end of the float valve arm. If it's in the UP position
jiggle it, so that it returns to the DOWN Position. That should stop the wter from overflowing the
tank.
2. If the bucket is not installed properly into the bucket holder. Remove the bucket, empty the
bucket, if necessary and reinstall it. Be sure that the bucket fits "squarely" into the bucket
holder from top to bottom and that it does not tilt downward at the bottom.
It's also a good idea to check the pump switch for continual draining, to make sure it hasn't been accidentally turned ON.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 28, 2011 | DeLonghi DE500P Dehumidifier
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
It has been on for 24 hours in a damp basement and has collected hardly any water.
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 13, 2010 | Woods WD25G Dehumidifier
Quad gear oil leaking....what do I need to do to fix this and will is cause problems if a person still rides it with it leaking?
dissassembly will be required to replace seals, riding with it leaking will allow water to get inside the housing and ruin the bearings and or gears
Aug 15, 2010 | Yamaha RD 250 Motorcycles
Leaks water from back
this is not a water leak ! it is the humidity in the room which collects as water and drains out at the back.keep a bucket underneath or attach a drain pipe to the outlet .
May 31, 2010 | Goldstar WG8000 Air Conditioner
Water is no longer collecting in bucket, but appears to leak out of humidifier. Humidifier also ices up.
Basically there is a drainage blockage from the humidifier to the bucket. Take one for the boys and **** hard on the pipe which very possibly will release the blockage.
May 23, 2010 | Kenmore 54351 Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Royal Sovereign White 1200 BTU/12,500 Heating Air Conditioner Logo
123 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
