Toshiba washing machine manual- AW- 1190S - Washing Machines
kalamazoo222
  • 285 Answers
SOURCE: i have TOSHIBA AW 8500
Toshiba does not seem to support washers in USA. You should go to Toshiba worldwide support at http://www.toshiba.co.jp/worldwide/index.html. Select your country and follow the steps to get a phone number. Talk to a CSR and they should be able to give you a part number and/or dealer near you.
It sounds like you need the Lint trap for your Toshiba AW 8500S washer. Good luck!
Posted on Nov 29, 2010
SOURCE: I have a Toshiba Washing
aoa may machen is toshiba problem is timer not work and led blinking you gev meen anser waht porblem hai thanks
Posted on Jun 09, 2011
  • 6277 Answers
SOURCE: My washing machine modle toshiba
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 27, 2011
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Posted on Aug 28, 2011
ezalyimtiyaz
SOURCE: toshiba aw-1190s error code E7-4
MY WASHING MACHINE APPEARS ERROR 2 AND 3.PSE CONTACT 019-2450009 0R EMAILS EZALYIMTIYAZ@YAHOO.COM. ANY SUGGESTION PSE?
Posted on Dec 15, 2012
The lid of my toshiba aw-1190s top loading washing machine would not open what could be the problem
Sounds like it has been locked. Is the power on it on or off? It will lock the lid, as shown by a red light (normally). Switch the power off, and it should unlock. If not, unplug it and it should unlock itself. If it does not do that, it may be that the lock is engaged and the mechanism damaged. Let us know what you find out after turning the power off, or unplugging it.
Sep 10, 2017 | Washing Machines
Toshiba washing machine When I push on the error E7-4 shows and then it turns off what is E7-4 error ?
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
Jul 31, 2016 | Washing Machines
Toshiba aw-1190s error code E7-4
Nov 17, 2012 | Office Equipment & Supplies
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
User manual for toshiba washing machine in english
i need Toshiba AW-F50VP Washing Machine English User Manual
Feb 14, 2011 | Washing Machines
I have TOSHIBA AW 8500 S washing machine... there is one part which located inside washing tub (part with net) where all dust nd all accumulated during washing, is comppletetly destroyed.... i want want...
Nov 29, 2010 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Nov 13, 2010 | Washing Machines
Washing Machines Logo
525 people viewed this question
Top Washing Machines Experts
