Error f11 indesit - Washing Machines
  • Washing Mach... Master
  • 744 Answers
F11 pump cannot be activated, not the same as F05 pump blocked, You may find that the pump coils have burnt out, but please unplug before trying to take a look, if the pump looks ok
this video will help
Posted on Jul 22, 2013
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Tip
    List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
    Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
    All this brands share parts, they share the same error code list, and the service is provided by same centres.
    I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
    Washing Machines and Washer Dryers
    • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
    • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
    • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
    • F13 - Check the water supply, inlet valve and hot and cold hose connections.
    • F14 - A fault with the water heating has occurred
    • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
    • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
    • F17 - Door not closed properly. Close door firmly at 3 o'clock position
    • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
    • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
    • F40 - Water below protection level during a heat step
    • F41 - Water level detect sequence incorrect
    • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
    Fault codes for LCD EVO1 Washers
    • F01 - Short circuit motor triac
    • F02 - Motor jammed tacho detached
    • F03 - Wash thermistor open/short circuit
    • F04 - Pressure switch jammed on empty
    • F05 - Pressure switch jammed on full
    • F06 - Program selector error
    • F07 - Heater relay stuck
    • F08 - Heater relay cannot be activated
    • F09 - Incompatible eeprom
    • F10 - Pressure switch not sensing correctly
    • F11 - Pump cannot be activated
    • F12 - Communication error
    • F13 - Dryer fan or dryer thermisotor fault
    • F14 - Dryer element fault
    • F15 - Dryer element relay fault
    • H20 - Not fillings. Check tap, hose and inlet valves
    • LOCKED - Check interlock
    Fault codes for LCD EVO2 and V4 Washers
    • F01 - Motor traic short circuit
    • F02 - Motor jammed or tacho detached
    • F05 - Pressure switch jammed on full - Check pump for blackages.
    • F08 - Heater relay stuck
    • F09 - Setup error
    • F12 - No communication between cards
    • F13 - Drying thermistor open/short circuit
    • F14 - Drying element faulty
    • F17 - Interlock error
    • F18 - Communication error
    • H20 - Not filling. Check tap, hose and inlet valves
    Fridges and Freezers
    • F1 - Freezer thermistor open circuit
    • F2 - Freezer thermistor short circuit
    • F3 - Fridge thermistor open circuit
    • F4 - Fridge thermistor short circuit
    • F7 - Evaporator thermistor open circuit
    • F8 - Evaporator thermistor short circuit
    • F9 - Temperature set switch open circuit
    • FA - No feedback from Baffle
    • FB - Fridge Baffle motor operating continuously
    • FE - Defrost time out
    Dishwashers
    • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
    • F11 - Heater timed out. The heater has not reached the required level.
    • F20 - Temperature under range
    • F21 - Temperature over range
    LCD Dishwasher Models
    • A01 - Float switch
    • A02 - Open/Short circuit heater relay
    • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
    • A04 - Unable to reach or sense temperature within 70 minutes
    • A05 - Pressure switch has not been reset
    • A07 - Open/Short circuit wash motor triac
    • A08 - Open/Short circuit auxiliary wash motor triac
    • A09 - Open/Short circuit with main wash traic
    • A10 - Open/Short circuit fill valve traic
    • A11 - Half load valve traic or alternating motor action
    • A12 - Open circuit heater rely
    • A13 - Open/Short circuit dispenser traic
    • A14 - Drain hose too low causing syphoning. Check drain hose.
    • H20 - Check tap and pressure of incoming water.
    Hotpoint Tumble Dryers
    • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
    • F2 - Thermistor or sensing circuit failure
    • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
    ...Follows--->
    on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
    How to take out water pump
    There are two ways of fixing drain pump depending on serial number of appliance. One easy mounting with three screws and the other is using the anchor tab where you should turn the drain pump counter clockwise and remove.
    25602824-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Also, follow this link:
    http://www.espares.co.uk/advice/0/2308/indesit-washing-machine-pump-replacement-and-f11-error-
    Dado
    Mar 23, 2015 | Indesit Washing Machines
    F06 error on indesit WD 61451 washing machine
    Could be the program select error, but why not check all error codes and save them on the Indesit site yourself.
    Error Codes Indesit Service
    Feb 25, 2015 | Indesit Washing Machines
    F-03
    f01 light 4, motor triac
    f02 light 3 motor, jammed/ tacho
    f03 lights 3&4 Ntc fault
    f04 light 2. pressure sw stuck on empty
    f05 lights 2&4, pressure sw stuck on full
    f06 lights 2&3, N/A?
    f07 lights 2&3&4 heater relay
    f08 light 1. heater relay
    f09 lights 1&4 eprom/setup error
    f10 lights 1&3, pressure switch not sensing
    f11 lights 1&3&4, pump/draining error
    f12 lights 1&2, communication error
    f13 lights 1&2&4, dryer ntc/ fan motor
    f14 lights 1&2&3, dryer heater
    f15 lights 1&2&3&4, dryer heater relay
    f16 N/A
    f17 light 4, door lock
    f18 light 3 comms error (3 phase motor) power board
    f1 and f17 share the same light
    Jun 21, 2011 | Indesit W 123 Front Load Washer
    Just new out of the box. Will wash ok but won,t release water, then error code F11 appears with all lights flashing.
    Dec 31, 2010 | Indesit Washing Machines
    Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
    Hi, this is the list of the Indesit wd12 error codes...
    Error codes and their meaning..
    f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
    Door flashing 9 times means 1&4 eprom/setup error
    Dec 20, 2010 | Washing Machines
    Indesit W1E 127 showing fault code - F - 11
    This is a drainage problem.First thing to check is the filter behind the kick plate at front of machine.
    Please note that there will be water in the system.
    Please post back your findings for further assistance if required.
    Thankyou for using Fixya.
    Jan 24, 2009 | Indesit WA 115 Front Load Washer
    A05 code
    Indesit Error Messages and Error Codes Indesit Dishwashers
    • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
    • F20 - Temperature under range. Book a service engineer. .
    • F21 - Temperature over range. Book a service engineer.
    Fault codes for Indesit LCD Dishwasher Models
    • A01 - Float switch operated - Book a service engineer.
    • A02 - Open/Short circuit heater relay - Book a service engineer.
    • A03 - Short circuit on thermistor - Book a service engineer.
    • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
    • A05 - Pressure switch has not been reset - Book a service engineer.
    • A07 - Open/Short circuit wash motor triac - Book a service engineer.
    • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
    • A09 - Open/Short circuit with main wash traic - Book a service engineer.
    • A10 - Open/Short circuit fill valve traic - Book a service engineer.
    • A11 - Half load valve traic or alternating motor action - Book a service engineer.
    • A12 - Open circuit heater rely - Book a service engineer.
    • A13 - Open/Short circuit dispenser traic - Book a service engineer.
    • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
    _uacct = "UA-1207243-4";urchinTracker();
    Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
    Washing Machines Logo
    62 people viewed this question
    Top Washing Machines Experts
