Question about RCA Universal Remote Control
Program remote controlRCARCUGLWL
I have a Sharp digital 19" TV I want to program with my remote controlRCA modelRCU4GLWX
    Top Expert:
  • RCA Master
  • 75,471 Answers
To know about the programming instructions to RCA universal remote control, check the sites linked here. It is not practical to type in all of it here by this window. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://remotesearch.blogspot.com/
Posted on Jul 22, 2013
2 Suggested Answers
  • 5 Answers
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
Posted on Jan 14, 2009
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
I need the code for an RCA remote model RCR311W for a sharp tv
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Mar 04, 2011 | Televison & Video
Sharp tv ...want to use Rca remote D770 how do I program the remote?
Press and hold the device button you want to program (TV). Then type in one of the codes for Sharp TV's:
1004, 1006, 1012, 1029, 1095
1111, 1112, 1113, 1122, 1171, 1173
Release the TV button and press the on-off button. If that doesn't work, press the device button and try the on-off button again. Continue trying codes until one works.
Another thing to try: Turn on device. Press and hold the button for device you want to program, press the on/off button and hold until the LED turns on, and then release both buttons. Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off. When the device turns off, stop pressing play. Press REVERSE, wait two seconds and continue doing this until the device turns back on. To finish programming, press and hold STOP until the LED turns off.
If neither of these methods work, the remote probably isn't compatible with your TV (manufacturing dates matter; newer tv's often don't work with older universal remotes). In that case, try remotes.com for a exact duplicate of your TV's original remote. http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=19C140&uuid=12795625009490
I hope this helps.
Jul 19, 2010 | Sharp 19C140 19" TV
Sharp Aquos tv remote Programming code for Pace(Mediacom)cablebox
Check the cable box for the manufacturers name and see if that isn't listed in your owners manual.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
19 inch sharp TV - hooked up to exterior antennae - video problem
You should check the set with another video source to rule out the set from being defective. The process of elimination is the only way to find out where the problem is.
Jerry G.
Dec 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
CODE TV CODE DAEWOO DTG18
codigo para tv panasonic controlrca modelorcu703sp urjente
Jul 08, 2009 | RCA ACC-RCAURC Remote Control
My Sharp LC46sb54u does not let you program digital channels from the antenna. The option is deleted on the setup menu. How do you get the digital option back? The manual says once you program channels for...
Go to page 19. Make sure antenna setting is on DIGITAL
Then go to page 11. Change AIR/CABLE option to cable.
Then run the "Analog & Digital Search Start". The digital option should come back.
Jun 16, 2009 | Sharp LC46SB54U 46 in. LCD TV
Remote codes
http://www.oneforall.com
Hope this helps.
Len
Feb 27, 2009 | Televison & Video
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Jan 01, 2008 | One For All URC-3021 Remote Control
Televison & Video Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
