Question about Garden
How to change the oil on a Briggs & Stratton 450
    Sergeant:
  • 342 Answers
Sandy you can either drain the old oil from the spark plug socket which would be easier or the oil fill point. Remove the spark plug and tilt mower foward getting someone to hold a pot under it. When it's finished draining only put the same amount of oil back in (fresh) When you have done leave the mower somewhere level for a few hours and then start it. It may smoke for a few minutes.
Posted on Jul 24, 2013
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
smartr10U
  • 1305 Answers
SOURCE: what type of oil for a 650 series briggs and
B/S webpages show that they recommend a Synthetic 5w-30 oil for their small motors...
K
Posted on Aug 29, 2009
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
kel1guy2002
  • 3740 Answers
SOURCE: Does the Briggs & Stratton 650 series have an
Hi and welcome to FiXya. I am Kelly.
The 650 series engines are a splash oil lubricating system 6.5 Hp engine. There is not an oil filter on this engine.
The manufacturer specs on this engine state to do the first oil change after 5 - 8 hours of use and then at 50 hour intervals there after.
You should use SAE 30W oil for your engine and if you use "synthetic" oil, it does NOT change the interval period.
Here is the actual engine operators manual:
http://www.briggsandstratton.com/pdf/owners_manual/100%5C277039-Domestic.pdf
Oil change procedure is on page 10 of the manual.
Thanks for choosing FixYa.
Kelly
Posted on Jul 31, 2010
rycgl
  • 1545 Answers
SOURCE: What is the magneto gap for a 6HP Briggs &
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Posted on Jun 10, 2011
Why is my 450 series 148cc briggs and stratton lawn mower engine running fine and then when it gets hot it runs with no throttle
Keep an eye on the oil level, it could be sucking oil past the rings and burning it causing the engine to run a bit faster. it may also have a small vacuum leak at the carb or manifold tube, make sure the carb and manifold gaskets are not leaking air. All combustion air must pass through the carburetor exclusively.
Jul 28, 2014 | Briggs & Stratton Garden
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
What oil to use 148cc briggs & stratton 450 series
main jet clogged and use plain 30 weight oil in it not not 10w30
May 02, 2012 | Briggs & Stratton Briggs Stratton...
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Feb 10, 2012 | Briggs & Stratton Garden
I have just aquired a Briggs and Stratton 450 series self propelled mower but need an owners manual.
The Briggs and Stratton 450 series is the engine (4.5 Hp). Is there a model number on the mower deck anywhere? I can probably find you a manual but need that model number. Unless you just want an engine manual.
Murray makes a 20 inch MX450 that has the Briggs and Stratton 450 engine on it but there are numerous makes and models (self propelled) that use this engine.
MX450 parts manual is here:
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=lminvFXBnfBhU7y
If you can come up with a good model number I will search avidly for a manual.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
Does the Briggs & Stratton 650 series have an oil filter?
Kelly
Jul 31, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
441 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
