Question about Cardo Systems Cardo Scala Rider G9
I have a Scala Rider G9 Power set, When I use unit A to speak with unit B, unit B can ear me but it is vary faint even with volume at max. When I use unit A to make phone call it work just fine. When unit B plays music, there is no problem
My one set of Scala Rider teamset pro will not let the second set talk to it but the microphone works- any solution?
Do the 2 units pair up when you switch on ? If they do try swapping the units to see if the problem changes from one helmet to the other.
If it does then the problem is with one of the units, if it stays with one helmet then it may be a wiring problem to the speakers.If they dont pairup when you switch on try re-setting the pairing and start again. With the unit turned on, press and hold the CTRL button for 6 seconds till the light flashes red then blue rapidly then press the volume up button for 3 secs, the red/blue should flash 5 times to confirm reset done. Then re pair the units for intercom, switch both units on, when they are flashing slow blue on one unit press the CTRL and Intercom Buttons simultaneously for 6 secs so the red light flashes rapidly, repeat for the 2nd unit, they should both go to a solid red light within a few seconds then slow flash blue to show they have paired for intercom use. If this does not cure the problem you will probably have to send the units for repair.
Hope this helps
Tim
Jul 03, 2014 | Cardo Scala Rider Teamset Pro
Charge light on scala q3 does not go off when charging
I am more familiar with the G4 and G9 models but usually when the charging light will not go out the battery is beginning to fail. I believe I read that these models contain the same battery as the original classic Ipod. They can be found on ebay or Amazon.
I have batteries for the G4 and G9 models. I can be reached at Chris at RoamingDZ dot com. or 478-227-9445
Apr 12, 2014 | Cardo scala-rider Headset
Scala rider connects to phone 1 and phone 2 and after 10-15 seconds it shut down
give it back. I also have problems with my Scala rider Q1 system. I would not pay R 200 FOR THIS TYPE OF RECEPTION and i have payed R3000. Bad deal.
Oct 29, 2013 | Scala-Rider Cardo Scala Rider Q1 TeamSet...
My scala rider G4 set has lost hearing in one of the headsets. Where is an authorized rapair shop?
Cardo had a problem in the firmware of the early models that caused the auto adjust on the volume to overload the speakers. Not knowing how old your unit is I have no way of knowing if this is the problem. If you still have the units you can buy new audio bases. I also have a source for replacement batteries.
Aug 26, 2012 | Cardo scala-rider Headset
I HAVE LOST THE INSTRUCTION MANUAL & WANT TO USE THE SCALA RIDER WITH MY garmin nuvi sat nav
Please find here a link to google search where the first 2 results are for the scala rider headset
http://www.google.com/search?q=scala rider user manual
Jun 20, 2011 | GPS
My scala rider battery won't hold a charge in standby - typically goes flat in about 8 hours. And I cannot get a reply about it from Cardo
Guys, if you roll out a device that can detect the battery if you own a soldering iron it can be easily replaced by a similar or even greater capacity.
Oct 12, 2009 | Cardo scala-rider Headset
Volume
I had a similar problem when I first connected my Cardo Scala Rider set to the helmet. First off, make sure that the volume on the Zumo is set to 100% for BOTH guidance and mp3 functions. Then click the upper control on the Cado Scala to maximize the volume of the headset. When you've accomplished those two electronic hurdles, adjust the location of the speakers in the helmet - if location of the speakers is not optimized nothing you do with the electronics will have much effect. I typically run the mp3 volume at 20% and the GPS at 50% with the headset volume at halfway. My Cardo Scala unit is a Teamset and I sometimes have problems hearing my rider scream that I'm going too fast. I haven't bothered yet to tell her to keep the microphone closer to her lips.
Aug 07, 2008 | Garmin zumo 550 GPS Receiver
Cardo Systems Cardo Scala Rider G9 Logo
35 people viewed this question
Top Cardo Systems Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Cardo Systems Radio Communication Expert? Answer questions, earn points and help others
