Bush 24" full hd led24970dvdfhdw can not tune channels as it has been set up by someone else in the past and no longer offers the tuning process. What can I do???
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
SOURCE: Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
Posted on May 27, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
SOURCE: LCD-32 TV.Can not tune in channel 7
81CM HD Sanyo LCD: Was still under warranty, took it recommended repair man and he simply tuned it at his shop!. Perfect when I connected it at home...Bob Tape
Posted on Jul 29, 2009
SOURCE: will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
Posted on Oct 27, 2009
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
I re-tuned my TV (Samsung) on 03/09/14 as suggested by the pop-up message. i have now lost channels that are not listed as changing - namely Channel 24 (ITV4) and all the HD channels. i have tried the
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 07, 2014 | Samsung Televison & Video
Tuning television why have chanels gone to 800
You need to complete the tuning process and set the region where you live. This will sort the channels in the correct order.
Sep 04, 2014 | Samsung LE40B650T2 40 in. Full HD Crystal...
HD option no longer appears on screen
Some settings have got changed. Please go to menu and try resetting it.
Jul 25, 2012 | Televison & Video
I have inadvertently mistuned in my tv and some programmes are not there now.Please advise how to re-tune my tv as the HD is no longer on it. Thank you.
Simple way to do is automatic tuning.Press Menu, go to Channel set up (Programme), select Auto Tuning. Your available channels will be set up in order of their channel numbers. Later you can shift the channels at desired programme number.
sonsunny
Jun 18, 2011 | Sony Televison & Video
How do you tune in to get freeview HD on the TXP42S21B
You simply need to perform the auto-setup when you first use the television. The freeview HD channels will tune in at the same time as the standard def. (SD) channels. You will find them in your channel list but there are only 3 freeview HD channels currently available - BBC HD (Channel 50), ITV1 HD (Channel 51) and Channel 4 HD (Channel 52).
If these channels are missing, it's may be because the HD broadcasts haven't started in your area yet. Please visit this page and enter your postcode to find out if you can get these channels:
http://www.freeview.co.uk/availability/
If you've gone past the auto-setup and you need information on how to tune your TV, please consult your manual or post back here and I will assist you.
Please rate this solution if you find it helpful. Thanks.
Oct 18, 2010 | Panasonic Televison & Video
When turning on the Sony KV-28DX20u TV I find that all the program settings have been lost. Have retuned the set but after turning off and on again these settings are again not saved.
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
Mar 28, 2009 | Sony KV-28DX20 28" TV
Full screen view
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
