Home | Logitech | 250 Headset | Vista and yahoo voi...
Logitech 250 Headset
Problem for Logitech 250 Headset
Vista and yahoo voice compatability
By jdog77 on Aug 29, 2007
voice chat wont work
Sponsored Links
Same Problem
May 05, 2009
-   cant hear me when i talk-   Guest
May 01, 2009
-   i cant get voice in yahoo chat using vista...can you help me solve the problem
-   freeneasy200
Apr 23, 2009
-   cannot get voice to work in yahoo chat rooms-   thatonechick
Apr 19, 2009
-   i go into a yahoo chat room and i cant hear anything it says my audio format is not compatable voice wont work at all-   truelilmama
Mar 30, 2009
-   my chat makes the freakin most annoying sound ive ever heard over voice... its like screaching... a really loud screaching. -   Guest
Best Solution
posted on Jun 09, 2008
Very Helpful)
Magster515
Rank: Apprentice
Rating: 97%, 41 votes
I had the same problem(s) with Vista and Yahoo Chat. I ended up with a simple workaround that doesn't involve downloading codecs etc., from 'suspicious' places, that may or may not work with your particular flavor of Vista..
First, go here: http://www.ymessengerblog.com/blog/2008/05/29/new-release-of-yahoo-messenger-90-beta/ and get the newest Yahoo Messenger 9.
Then go into a Yahoo Chat room. (I'd suggest one of the romance ones as there are usually quite a few attention strarved women and desperate men chatting away on mics.) When you click on the "Voice" button, you'll probably see this,
"this computer does not appear to have input, or it is not configured correctly" (which doesn't seem a whole lot better than the original compression issues,) BUT, all you have to do is plug in a microphone and everything works just tickety-boo. If you don't have a mic, just plug some headphones INTO the INPUT for the mic. You'll still hear everything just fine through your speakers.
It's not an ideal solution but unless someone out there remembers more than I do about their days as a 'sound guy' for local bands, it shouldn't do any harm.
Good luck.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #2
posted on Apr 24, 2008
Very Helpful)
jamstan
Rank: Guide
Rating: 96%, 38 votes
That tsp codec worked with the original Vista. I used it to fix the voice on the original Vista but after installing SP1 the voice quit working. If you have SP1(you should) don't bother with the tsp codec--it won't work.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on May 27, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #4
posted on Feb 17, 2008
Helpful)
frawgz
Rank: Apprentice
Rating: 95%, 41 votes
http://www.freecreed.com/vistavoice.html as a file patch that works 99% of the time
Was this helpful?
Yes
No
Solution #5
posted on Apr 13, 2008
Helpful)
jerryg50
Rank: Wiz
Rating: 84%, 872 votes
Vista has many issues with drivers and some devices, and especialy older devices. SP-1 for Vista is supposed to make Vista more compatible to XP for drivers and softwares. You will know when you have SP-1 installed.
Most businesses are refusing to go with Vista at all. They are demanding XP-Pro only. Many were saying that Vista is so bad for issues that if they cannot go to XP-Pro they will go over to Linux.
As for Vista, I really like the look of it, and the way it handles. I am waiting to see how it works out with SP-1. For that reason I am holding off on my next PC. When I tried Vista for a client on a new computer I had too many problems with it. Out it went, and I was back on XP-Pro for him. If Vista still has the problems I will be going with XP-Pro, or possiblity Linux.
Jerry G.
Was this helpful?
Yes
No
Solution #6
posted on Apr 29, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I wrote a program in C# to fix the Yahoo! voice chat issue in Vista
You can get it here http://shadow-corp.net/smf/index.php?action=tpmod;dl=item50
Built in C# .NET 2008 so fully vista compliant
Should work on all 32 bit versions of vista
Solution #7
posted on Jul 29, 2008
Helpful)
scubaron
Rank: Apprentice
Rating: 92%, 7 votes
i down loaded 9.0 messenger and chat rooms voice and sound are good now
Comments:
Jul 30, 2008
- REMOVE MESSENGER 8.1 AND INSTALL 9.0,THAT WORKED FOR ME!!
Was this helpful?
Yes
No
Solution #8
posted on Oct 18, 2008
Helpful)
alzamann
Rank: Apprentice
Rating: 89%, 4 votes
Using Yahoo v9 final supposedly installs a voice codec for chat room voice, but unmerous people have problems with v9.
I use Yahoo v8.1, and downloaded the codec here:
http://www.bytescribe.com/downloads/tsp_codec_install.exe
  • After installing close Yahoo
  • Right click the shortcut for Yahoo on your desktop and select "Run as Administrator"
  • Reboot Comp
Works for me :)
Was this helpful?
Yes
No
Solution #9
posted on Oct 20, 2008
Not Helpful)
jay_dawg76
Rank: Apprentice
Rating: 47%, 2 votes
http://www.bytescribe.com/downloads/tsp_codec_install.exe it works ive used it just make sure ur on the latest version of yahoo
Was this helpful?
Yes
No
Solution #10
posted on Dec 08, 2008
Very Helpful)
vikas14
Rank: Apprentice
Rating: 100%, 2 votes
the provlem is due to the windows vista and the audio drivers both. intel is using puter hd platform on newer chipsets the two most common drivers used for hd audio are realtech and sigmatel IDT high def. codec, the problem occours when u have vista service pack 1 because these audio drivers are specially designed for vista service pak 1 so when u try to install tsp codec or the messanger the vista refuses to accept the codec which is requred by messabger so end result is u do not get sound in confrence but i found one solution for this
Solution - the solution for this problem is install a yahoo verson in which the codec is intigrated or intigrate the codec into yahoo so u can down load the link from bellow i am giving u a new messanger which has intigrated codec..........enjoy 100 tested it will solve all problems.......
http://rapidshare.com/files/171316081/yahoo_9_with_inbuilt_codec.rar
Was this helpful?
Yes
No
Solution #11
posted on Nov 26, 2008
Very Helpful)
tota2
Rank: Apprentice
Rating: 100%, 1 votes
i have a problem with the voice in chatting it alwas comes a words saying the voice compression format what can i do?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #12
posted on May 09, 2009
Somewhat Helpful)
timbuktu
Rank: Apprentice
Rating: 75%, 2 votes
I tried all the downloads and none of them worked. Then someone had the solution on here to plug a set of headphones into the headphone outlet on the back of your computer and now everything works just fine!! What a simple solution THAT WAS since I downloaded Yahoo 9.0 and still had the same problem!!
So...plug an old pair of headphones into the headphone jack and you'll be able to hear voice..:)
Was this helpful?
Yes
No
Solution #13
posted on Apr 16, 2009
Not Rated)
miss_cuddles
Rank: Apprentice
Rating: 0%, 0 votes
im new to vista and i cant get voice in yahoo no matter what ive tryed help me plzzzzzzz sound works on everything but yahoo chat
Was this helpful?
Yes
No
Solution #14
posted on Apr 09, 2009
Not Rated)
reene58
Rank: Apprentice
Rating: 0%, 0 votes
if your on vista and can't get voice go to yazak download and just download the
VBRundll and the vista voice fix then reboot.you can find yazak download in search
r
Was this helpful?
Yes
No
Solution #15
posted on Jan 08, 2009
Not Rated)
rich_57
Rank: Apprentice
Rating: 0%, 0 votes
go here and do as it says >> http://www.yazakpro.com/chatstuff/yahoo/vistayahoovoicefix.html
this will fix yahoo voice..
Was this helpful?
Yes
No
Solution #16
posted on Dec 02, 2008
Not Rated)
yahpain
Rank: Apprentice
Rating: 0%, 0 votes
http://www.bytescribe.com/downloads/tsp_codec_install.exe install it and reboot computer!!! then open voice voalllaaaaahhhh
Was this helpful?
Yes
No
Solution #17
posted on Nov 01, 2008
Not Rated)
Scott Ellin
Rank: Wiz
Rating: 83%, 321 votes
This is the best I got it here,
Just download the latest updates for your Operating system from Microsoft
Then download the latest version of yahoo which is offcourse yahoo messenger 9.0
After install, reboot PC and then use it ..
Hiya! And We got fix it!!
Thanks FixYa.!
techin.scott@gmail
Comments:
Nov 01, 2008
- NOTE: Before doing anything close any instance of Application running and quit all internet & websites program.
Disable your Firewall, Antivirus and then reboot PC after Microsoft updates.
Then go for installation of Yahoo messenger. Problem related to yahoo chat will resolve in few minutes.
Was this helpful?
Yes
No
Solution #18
posted on Oct 15, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
this is why people have to pirate programs. we buy the real thing only to get a ton of problems
Solution #19
posted on Oct 12, 2008
Not Rated)
k_lee_14
Rank: Apprentice
Rating: 0%, 0 votes
i have a new laptop with vista and can not get voice in chat rooms says it is not configurated
Was this helpful?
Yes
No
Solution #20
posted on Oct 08, 2008
Not Rated)
barako431
Rank: Apprentice
Rating: 0%, 0 votes
help me
Was this helpful?
Yes
No
Solution #21
posted on Oct 02, 2008
Not Rated)
alii_lucky
Rank: Apprentice
Rating: 0%, 0 votes
this computer does not support the required audio compression format I HAVE THIS PROBLEM PLEASE HELP
Was this helpful?
Yes
No
Solution #22
posted on Sep 20, 2008
Not Rated)
thekaufmanns
Rank: Apprentice
Rating: 0%, 0 votes
no voice on yahoo chat i'm using vista
Was this helpful?
Yes
No
Solution #23
posted on Sep 18, 2008
Not Rated)
wwe_fahad
Rank: Apprentice
plz plz plz Solve my yahoo voice chatting problem plz plz plz my id iz this!
Comments:
Oct 15, 2008
- plZ solve my yahoo voice error plz plz plz solve now plz........................
Oct 16, 2008
- plz solve my yahoo vice error plz plz plz.............................now plz.............
Oct 16, 2008
this is my idd plz solve now plz....................
wwe_fahad@yahoo.com
Was this helpful?
Yes
No
Solution #24
posted on Sep 16, 2008
Not Rated)
moon_queen_4
Rank: Apprentice
Rating: 0%, 0 votes
voice chat in yahoo rooms doesn't work
Was this helpful?
Yes
No
Solution #25
posted on Sep 11, 2008
Not Rated)
nafiwatever
Rank: Apprentice
Rating: 0%, 0 votes
my voice chat for yahoo wont work
Was this helpful?
Yes
No
Popular Solutions for Logitech 250 Headset
Questions and Unsolved Problems for Logitech 250 Headset
Do you recommend Logitech 250 Headset?
Answer
Answer
people can't hear me speak through earphone
Answer
when using on ps3 recently, the sound on the left side completely went away and my voice isn't being... (More)
Answer
I use vist window ..when in the chat room i can not her anyone speaking(voice)
Answer
i can hear the other person but they can't hear me
110 Other Users Have The Same Problem - Continued
Comment by rashi09, posted on Mar 28, 2009
i dont know how to vall in in version 9.0
Comment by Guest, posted on Mar 21, 2009
windows messenger 9 no sound on chat, but mic says its working!!! help
Comment by sweet_catoo2, posted on Mar 05, 2009
same problem no voice i cant say anything
Comment by Guest, posted on Feb 10, 2009
I JUST DOWNLOADED MESSENGER 9.O AND STILL CAN'T GET SOUND IN CHATROOM,OH AND I HAVE VISTA
Comment by sisterslyfox, posted on Feb 03, 2009
i donot have sound in chatroom with this new vista
Comment by radin_dc, posted on Feb 01, 2009
same problem
Comment by immi749, posted on Jan 28, 2009
yahoo chat room voice not working
Comment by Guest, posted on Jan 28, 2009
yahoo voice chat is not working
Comment by dneuro86, posted on Jan 18, 2009
I have a mic and seems to work fine but it is not letting me voice chat.
Comment by lilredriding, posted on Jan 16, 2009
i dont have mic but i was told that i should be able to listen in but i cant. my computer will not let me. i have a toshiba and it has vista on it but i cant hear anything i need help.
Comment by Guest, posted on Jan 05, 2009
when in yahoo chat rooms , I have sound but my talk button doesn't work so that I can play music or chat
Comment by Guest, posted on Jan 03, 2009
vista blows logs
Comment by allcountry26, posted on Jan 01, 2009
vioce chat yahoo will not work
voice chat will not work or their is sooo much static it is not funny
Comment by Guest, posted on Nov 30, 2008
I cant use the voice system on yahoo either that sucks big time .. why have if dont work?
Comment by Guest, posted on Nov 06, 2008
I have the same problem in my Lap TOp too...
Comment by blackice_87, posted on Nov 02, 2008
i have a new vista and can not get voice in chat rooms says it is not configurated
Was this solution helpful?
Comment by betta_do, posted on Oct 19, 2008
i allso have this problem . on my old comp, (a mac os x) it had an internal microphone...
surley there is allso an internal mic on my lap top ?
or is it strictly a vista home problem ?
Comment by Guest, posted on Sep 22, 2008
Messanger says no mic when there is one under vista.
Comment by taste_poetic, posted on Sep 10, 2008
my voice doesn't work in yahoo chat. I have Vista. I don't know why it won't work. Help please. Thanks!
Comment by noori66, posted on Sep 09, 2008
hi
yes i have yahoo voice problem with new vista home
could anyone please help and gide me
Comment by Guest, posted on Sep 06, 2008
I have the same problem I have vista and voice wont work on yahoo messenger
Comment by arvjr, posted on Sep 05, 2008
wont accept thesound format compression on vista
Comment by jerometj, posted on Sep 03, 2008
i upgraded to vista home basic for months now.
i try entering to chat rooms and i get a messsage
like this...the computer does not support the required
audio compression format.what will i do?
please help.thanks to everyone....
Comment by Guest, posted on Sep 01, 2008
its said audio compression format in chat rooms. help pls
PC to PC calls are fine. But cant get the voice chat 2 work with Vista
Comment by Guest, posted on Aug 31, 2008
Has anyone found a solution for Vist'a incompatibility with Yahoo voice chat? Peer to peer calls are fine, but voice chat...brick wall.
Comment by spec_e42000, posted on Aug 25, 2008
no voice chat i have windows vista
Comment by rajesh_dei, posted on Aug 23, 2008
voice compression no support
Comment by 2224, posted on Aug 22, 2008
this computer does not supported the required audio compression format
Comment by tamthanhd19, posted on Aug 22, 2008
this computer does not support the required audio compression format for window vista
Comment by sahito99, posted on Aug 21, 2008
when i jion yahoo voice chat a message appears your computer dont have audio compess support
Comment by Guest, posted on Aug 21, 2008
i get the same problem with yahoo messenger like the other, my pc os is widow viata basic
i got a new pc with vista and everytime i connect to yahoo chat rom it always pop a message "Computer does not appear to have audio input capability or its not configured correctly"i checked my computers audio and no problem in it. i tried looking for solutions and installed some tps codecs but it doesnt work. i never encountered this with xp before.
Comment by kokiloki94, posted on Aug 20, 2008
Everytime I try to do a voice chat on yahoo IM, it kept saying that my comp. didn't support that. I have a windows vista, is there any way I could get my mic working on it?
Comment by SLOGSDON83, posted on Aug 14, 2008
mY COMPUTER SAY DOES NOT AUDIO COMPRESSION FORMAT
Comment by Guest, posted on Aug 14, 2008
EVERYTIME i TRY TO DO SOME CHATING ON THE COMPUTER IT SAY THIS COMPUTER DOES NOT SUPPORT AUDIO COMPRESSION FORMAT
Comment by faytew, posted on Aug 11, 2008
everything i could find and it still wont work
Comment by mushtaqmaaz, posted on Aug 08, 2008
Voice call don't work and conference calls don't work at all. When I get into a conference room a message appears saying"This computer does not support the required audio compression format" . What shall do?
Comment by shosho1976, posted on Aug 04, 2008
Voice call don't work properly and conference calls don't work at all. When I get into a conference room a message appears saying"This computer does not support the required audio compression format" . What shall do?
Comment by unnidnair, posted on Aug 04, 2008
This happens to me too
Comment by mehta_manjit, posted on Aug 04, 2008
when i activate the voice chat in yahoo i got a message that this computer does support required voice format
Comment by cfifflisa, posted on Aug 02, 2008
i wont voice chat for yahoo chat rooms
Comment by Gwyddion_A, posted on Aug 01, 2008
I had all the same problems everyone else had and here's what I and a fellow Vista friend did to fix it. I had Yahoo Messenger 8.1 and confrencing didin't work though I could phone other computers. As suggested I in other post here I Uninstalled Messenger 8.1 and installed Messenger 9 Beta. It didn't work either but I could call. I Uninstalled Messenger Beta and installed Messenger Vista Beta. Nothing changed. Because everyone I was messeging with was using Messenger 8.1 I uninstalled the Messenger Vista and reinstalled Messenger 8.1 and it worked. All I can figure is that by installing and uninstalling the three versions a updated shared file or a codex was left behind during the uninstall. Nothing else was downloaded or done other than what I described. It worked for us immediately and it was simple and safe to do. Another thing that may be an issue is that different Beta versions of Messenger may not comunicate well with each other so find out what version of Messenger is being used by your friends. Good luck.
Comment by chapster49, posted on Aug 01, 2008
i cannot use voice properly on yahoo with vista. i can hear people but they only hear static from me. this is when i am talking through my cam mic. when i plug in my mic with ears i can neither transmit nor receive. very frustrating. pete
Comment by lyin, posted on Jul 28, 2008
I have the same problem, when I go to Yahoo chat, it says "I don't have audio compression format" I just bought this new Vista lap top and wondering what to do now. I love Yahoo and now I can't use it,,,,,,,,any help I would appriciate.
Thank you
Comment by scubaron, posted on Jul 28, 2008
no sound when in chat room,talk buttons are gray,not green?
Comment by Guest, posted on Jul 27, 2008
i wont voice and ears for yohoochat rooms
Comment by Guest, posted on Jul 22, 2008
yeah i hav tthe same problem in my dell lappy:(
Comment by walez21, posted on Jul 20, 2008
i can't speak in yahoo messanger and i faced a message that tell me the audio compression format didn't support in my computer which has the operating system vesta
Comment by Guest, posted on Jul 19, 2008
yahoo chat says my speakers arent compatible, i have vista, could you please tell me how to fix this problem? thanks
Comment by nbl5, posted on Jun 28, 2008
i dont have audio copression when i go to yahoo chat room
Comment by Guest, posted on Jun 28, 2008
when i go to yahoo chat room it says your computr does not support requried audio compression format..
Comment by renerieza_27, posted on Jun 21, 2008
when i go to chat room may loptop say this computer does not support audio visual compression format. please help me don t know what to do i m not so expert in loptop.
Comment by dnmemphis07, posted on Jun 20, 2008
same issue same message...tried headset too...I can use mic on laptop and headset in im to talk but not in chat...go figure???
Comment by Guest, posted on Jun 19, 2008
i can hear in a chat or an im but, they can not hear me
i can hear in a chat room or an im but they cant hear me at all
Comment by Guest, posted on Jun 17, 2008
when i log in to tahoo it says this computer doesnt support voice compression format i have mic cam vista on dell lap top
Comment by Guest, posted on Jun 12, 2008
no voice in chat rooms
Comment by Guest, posted on Jun 11, 2008
Comment by Guest, posted on Jun 08, 2008
no sound in yahoo chat rooms
Comment by Guest, posted on Jun 05, 2008
it doesnt have voice chat format when i use vista ultimate
Comment by Guest, posted on Jun 02, 2008
no have audio the chat room
Comment by Guest, posted on May 29, 2008
my yahoo messager audio doesn't work in chat ?
Comment by city_homicid, posted on May 25, 2008
vista wont work on yahoo chat room not getting vice to work
Comment by bigfisherman, posted on May 21, 2008
voice chat won"t work on vista
Comment by ravanshadow, posted on May 19, 2008
your computer is not audio component
Comment by Guest, posted on May 18, 2008
when i try voice confrence,i get a message saying"this computer does not support the required audio compression format"..i m really flustrated...this happens in my vista home edition.
Comment by east smile, posted on May 15, 2008
i have problem in my computer sice i used vista windows. when i get in yahoo chat , i cant hear the other and it sayes this computer does not supported the required compression format . i got tierd of this windows . we have to go back to windows XP .
Comment by Guest, posted on May 12, 2008
yahoo voice chating time eror is "this computer cannot support audio compressed format".how solve the problrm.my product is acer aspire 4720.
Comment by azoreangel, posted on May 11, 2008
The same as everyone else with Vista....no sound or voice in chatrooms. I've tried all the "fixes". Uninstalling, reinstalling, etc. nothing seems to work! It's very frustrating.
Comment by Guest, posted on May 05, 2008
i cant get voice in the chat rooms.
Comment by black helmet, posted on Apr 25, 2008
i can not use voice to chat at yahoo messenger, it says this computer does not support required audio compression format, i am also using window vista home basic with sp1
Comment by henry76444, posted on Apr 22, 2008
I cant get voice on Yahoo chatrooms. I tried downloading the fixes but still have no luck getting voice in the chatrooms. Yes, of course, I have Vista.
Comment by kiuygh, posted on Apr 21, 2008
this computer does not appear to have audio imput capability or it is not configured correctly
Comment by freddy59102, posted on Apr 18, 2008
no sound in chat
Comment by Guest, posted on Apr 16, 2008
cant get voice on yahoo with vesta
Comment by marty2008, posted on Apr 13, 2008
Every time I enter a Yahoo chat room I have a voice error that reads this computer does not support the required audio compression format and yes I have vista.
Comment by Guest, posted on Apr 13, 2008
i got tsp codes for yahoo with vista and still won't work any ideas
Comment by Nieuwiefan, posted on Apr 12, 2008
My voice chat doesn't work on my Vista laptop. Seems like a common problem but what is the solution?
Comment by hellboy854, posted on Apr 12, 2008
i dont have voice on cnferences and chat-rooms on yahoo,can anyone help me?
Comment by desertrose, posted on Apr 10, 2008
i have no audio on my yahoo chat
Comment by albert23, posted on Apr 09, 2008
''this computer does not appear to have audio input capability or it is not configured correctly''
Comment by Guest, posted on Apr 05, 2008
got vista and dont have audio in chat rooms...help!!!!!!!
Comment by Guest, posted on Apr 03, 2008
compression format for windowsvista vice in chatrooms
Comment by kssunshine04, posted on Apr 03, 2008
I've tried freecreed. My computer must be the 1% that doesn't work.
Comment by nisha24, posted on Mar 31, 2008
when will yahoo support window's vista?
Comment by Guest, posted on Mar 26, 2008
need to get voice chat for vista windows for yahoo chat rooms
Comment by apple pie, posted on Mar 25, 2008
i dont have voice in chatroom ,how can i fix it?
Comment by Guest, posted on Mar 22, 2008
vista is somehow incapable of letting me have sound in yahoo chat rooms
Comment by bojackbo, posted on Mar 21, 2008
this computer does not support required voice compression format from yahoo chat. I've installed the service pack 1 fo vista, but I still get the same error
Comment by Guest, posted on Mar 16, 2008
no sound on yahoo chat rooms
Comment by west982008, posted on Mar 15, 2008
i have no voice with yahoo chat get a message says my system doesnt have the required compression format for it
Comment by tease_me, posted on Mar 14, 2008
ur computer doesnt support audio compression format..!wat is dis?
Comment by Guest, posted on Mar 10, 2008
"this computer does not support the required audio compression format"that's the message i'm getting when I go to chatrooms
Comment by wolf02456, posted on Mar 07, 2008
voice won't work
Comment by Guest, posted on Mar 05, 2008
well its the same i did all the steps and still wont work for yahoo chat
Comment by Guest, posted on Mar 02, 2008
vista and yahoo chat wont work together... help me!!!!
Comment by Guest, posted on Mar 01, 2008
VERY disappointed my new pc has windows vista/does not allow me to hear convo in chatroom or talk on my mic
Comment by Guest, posted on Feb 21, 2008
that tsp codecs not work,it have only work 1 time for me after restart my pc it not work anymore,we must still wait till yahoo support voice in chat for yahoo on windows vista.
i hope they bring out fast the finall version from yahoo messenger for vista
Comment by maharot, posted on Feb 14, 2008
my chatmate can't hear my voice
Comment by Lissy107, posted on Feb 13, 2008
I just purchased this computer and has Vista. I Don't have audio when i enter in Chat Rooms. It's telling me that my computer does not appear to have audio input capability, or it is not configured correctly.
Comment by mark19943, posted on Jan 09, 2008
my headset works but will not work on yahoo chat. Now I am in a deployed location with no way to talk my family
Comment by wizard2000, posted on Dec 10, 2007
Acs Connect Failure
Comment by Guest, posted on Nov 15, 2007
I cant get voice chat to work using Vista
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Logitech 250 Headset:
Top Headset Experts
Rank: Guru Guru
Solutions: 1444
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Headset Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
