Question about Garden
I need pictures on what the axle is suppose to
I need pictures on what the axle is suppose to look like where the tire goes on and also what both sides of the tire r suppose to look lil on a Craftsman DLT 3000 riding mower. Someone please help this lady who has no one to do it. The first tire is the one I took off. Notice the black ring in hole on both sides of tire. Thie 2nd tire is the spare. Notice there is no black ring on one side. Look at the axle. Is something else suppose to be on there
  • 2,239 Answers
The first wheel and tyre in the video is complete, the second wheel in the video has the bearing and bush missing from one side, the bearing and bush are still on the axle that you are pointing at, they need to come off the shaft and press fit them back into the wheel, the mark around the outside of the tyre is a bead, this if fitted shows the tyre is true on the wheel, this is not so important on a slow moving tractor.
Posted on Jul 23, 2013
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 138 Answers
SOURCE: 2003 DLT3000 Craftsman riding mower. Air in tires
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Posted on Aug 26, 2009
backwoodsctr
  • 169 Answers
SOURCE: Adjusting a craftsman dlt 3000 riding mower
assuming that you are working on a briggs engine? regardless of make what the problem is that the needle and seat inside the carb is not sealing off the fuel flow from the fuel pump/fuel tank or both......gravity feed fuel systems are the worst about flooding, the only fix will be a carburetor repair with needle and seat replacement
Posted on Nov 25, 2009
mouse_kil
  • 93 Answers
SOURCE: I have a DLT 3000 mower every time I let off the
With out more information it sounds like one of the safety switches is faulty -most likley the one under the clutch pedal .To test this locate and unplug the ignition wire coming from the engine to the wiring harness the engine should keep going -- you will need to plug it back in to stop the engine.If this works then repair or replace the faulty switch.
I hope this helps
Andrew A
Posted on Apr 14, 2011
I have a 26 mongoose ravage and I need to know what size the axle bolt is for the front tire
There is no "axle bolt." The threaded rod that goes through the wheel (not tire) hub is called an axle. It is secured with axle nuts. the axle needs to be the correct diameter, length, and have the correct threads. It would be unusual to just need the axle, but if that is truly the case then take it to a bike shop and they can provide the correct part. Should not be expensive. However you need both tools and knowledge to replace an axle.
Oct 14, 2016 | Cycling
Tip
How to take off the rear tire on a Kawasaki Drifter 1500
1. Lay out a towel/cloth to set fender on and protect.
2. With bike on jack and raised(back tire/wheel just off ground), remove entire rear fender.
3. Unplug wire harness left side just to front of left shock after you remove screw/cover. There's a 8mm bolt just above and over. Same bolt opposite side of fender.
4. Remove the 4 (12mm) bolts holding fender bracket to rear housing (left) and swing arm rear (right). Hold it because it will tip back and bang! It's not real heavy but you do need to support it.
5. When removed set on towel/cloth you have ready.
6. Release pressure from brake caliper (push/pull on caliper) remove brake caliper and hang it by wire (coat hangers work great) so it's not dangling from hose. Do not touch or let anyone touch brake pedal.
7. Remove the brake caliper bracket bolt that goes through swingarm. Place a towel/cloth on floor beneath brake area.
8. Remove cotter key from axle nut.
9. Remove axle while holding axle on the left side with wrench. You can use a large crescent on the axle nut so you don't have to remove exhaust/muffler.
10. As you loosen, slide axle to the left till nut clears muffler.
11. Now when you can slide the axle out. Support the tire/wheel as it is heavy. Caution: As the axle slides out of the brake caliper bracket the spacer could fall and hit towel (which is why you put the towel there see? It prevents too much marring.
12, Now you have room to slide tire/wheel assembly over to right and disengage from the gearcase. Caution: There is a spacer in the center of the gearcase that sometimes falls out and sometimes stays in (most of time). Just make sure it goes back the same.
13. When you're ready for the re-install, grease the drive splines with good quality axle grease.
14 Re-install everything in the reverse order you took it apart.
15. Re- torque rear axle from the left side and hold axle nut (right side) with same large crescent you used to loosen the nut and install a new cotter pin. Doing it this way saves you having to remove the muffler.
on Feb 16, 2010 | Motorcycles
How can we keep the rear wheel from coming off of the drive shaft?
Lil' Rider Black 80-Kb901K Fx Wheel Repair Questions ...
www.fixya.com/.../p13170224-lil_rider_black_80_kb901k_fx_wheel_b...
Recent Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Blackquestions, ... How can we keep the rear wheel from coming off of the drive shaft?
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike Instructional Video .... Why does the right wheel keep sliding off the tire gear, leaving it free-wheeling? ... WORST piece of trash I've ever triedto assemble! congrats groupon, you ... axle through, this will keep the axle and motor and drive gear fitting tight.
Jan 08, 2016 | Lil' Rider Black 80-Kb901K Fx Wheel...
How do I remove the front tire on a 98 Flstf
Get front wheel off the ground.
Undo axle nut (left side). If needed, put a punch through hole in end of right axle end to hold from turning.
Loosen 2 nuts on bottom of fork clamp (left side).
Pull out axle from right side, PAYING ATTENTION WHICH AXLE SPACER GOES ON WHICH SIDE, AND IT'S ORIENTATION, IF IT IS STEPPED!!!!
Tire/wheel will fall out at this point, so HOLD ON TO IT!
Mar 16, 2014 | Harley Davidson FLSTF Fat boy Motorcycles
Rear driver side axle shaft has a lil play in it like its sliding the tire in and out just enough to feel like the rear end is pulling left and right a bit has new springs and shocks
might want to check the rear axle inside the pumpkin make sure everything is tight the check your axle bearings there should be little or no play
Dec 23, 2013 | 1994 Ford Crown Victoria
Hearing a humming noise from the right front of mazda 3 2005 and its not the tire.i replaced both front tires
hub assembly is the word that comes to mind they can make as much noise as a bad tire the easy way to check it out is with a really good flash light and the ability to get under the the vehicle look in on the back side of the wheel where the axle goes thru look for tinny lil pieces of metal that's the reason for the really good flash light the metal will reflect the light off that's the give away for me
Nov 01, 2013 | Mazda Cars & Trucks
When I turn my wheel to the right i get a wobble out of the front right tire. What would be the problem? Tires look fine but the axle does shift slightly from left to right would that be some problem? Or...
axle is supposed to do that. need to jack up wheel not take it off. and put hands at 12 and 6 pm and wiggle wheel if there is a lot of movement then the bearing is gone. if ok let down. take wheel off and jack back up. on the suspension there is an arm coming off it. thin bar. fixes to another bar. this is a drop link arm. not these work with the anti-roll bar that is on the front. pull on it if it moves out and in it needs changing and that is your problem. also change other side as when one goes it is best to change both side. easy job to do. on the anti-roll bar at the front there is some rubbers that hold it in place check them and if the look split or cracked would change them to wile you doing the drop links. you just unbolt them. pull the rubber out of the case and swap the rubbers and bolt back on with some locking seal.
Oct 13, 2013 | 1998 Toyota Camry
Manual 883- rear tire almost rubbing on the right and run light not work left side -help
One possibility is the rear axle isn't aligned so the rear wheel/tire runs true to the axis of the frame. This can be visible with the drive belt not running true on it's sprocket, pulling to one side of the pulley, rather than being about equal spacing on each side of the belt to each side of the pulley.
The other possibility is the rear wheel was removed, and the axle spacers weren't reinstalled in the correct position(s).
The axle spacers are different lengths, and are specific as far as which one goes on the left, which one goes on the right.
May 22, 2013 | 2010 Harley Davidson XL 883L Sportster 883...
2004 pontiac grand prix gt. humming noise while driving. Louder at 25 mph or higher. Changed front passenger side hub bearings due to when turning slightly left humming quiets. I stol have humming....
I change both wheel hub bearings when one goes
Doesn't matter what stabilizer does--- the bushings need
to be done-- so you say
Maybe you replaced the wrong drive axle
Put the front tires on the back to see what happens
Nov 30, 2012 | Cars & Trucks
How too remove rear axel horsehoe clips too remove axel?
In order to remove the axle, you need to go in through the rear pumpkin. Take the back plate off the rear pumpkin, then you will see where your axle comes in through the sides. Go back to the outer end of the axle, (where the tire goes) and push inward on the axle. It shouls move in about 1/2" or so, just enough to remove the clip. The clip should fall out easily if it is turned in the 'down' position. Then you will need to remove the pins that run through the axles themselvs, and the axles should pull right out to the sides.
Apr 06, 2010 | 2004 Ford F150
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
