Question about Frigidaire Refrigerators
Service bulletins evaporator coil
2 Suggested Answers
  • 9 Answers
SOURCE: evaporator coil continue frosting\build up ice
check the indoor fan motor, the indoor fan motor has to be running while condenser is on. make sure the filter is clean and the return vents are not blocked. Check charge.
Posted on Dec 16, 2009
Temp reading 56 an had a flashing service this morning. lost most dairy prods. i did shut off and back on and flashing service stopped but temp is still 56
Check for ice buildup in evaporator coils also check for bad evaporator fan motor. Clean condenser coils.
Aug 03, 2017 | Refrigerators
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
I need a wiring diagram from ignition to starter to coils
www.bbbind.com free wiring diagrams ! click on Technical Information, then four box will pop up. click on
Technical Service Bulletins & Wiring Diagrams
Technical Service Bulletin (TSB) & Wiriagram DaEND-USER LICENSE AGREEMENTtabase
Apr 02, 2015 | Cars & Trucks
Pocket scan PO441 code
P0441 TOYOTA - Evaporative Emission Control System Incorrect Purge Flow
Possible causes- Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Incorrect fuel tank vacuum relief valve
Tech notes There are factory service bulletin for the following Toyota models:
2003-2004 Toyota 4Runner
2003-2004 Toyota Tundra
2004 Toyota Camry
2004 Sienna
2004 Highlander
2004 Solara
Toyota Factory Service Bulletin OBDII Code P0441
Sep 14, 2012 | 2003 Toyota Highlander
Kmonogram built in refrigerator, where is the evaporator coil and how to vacuum it.
Finding the evaporator will take disassembly of parts of the cover on the top of refrigerator. If you have other questions please let me know. Just be really careful to not damage the evaporator and unplug before working on your Monogram you need to find the evaporator coil to repair, replace parts or work in that area it is on top of the ZISS480NRSS and listed as part location #800 in the photo below. Click below to enlarge,
ZISS480NRSS Parts ZISS480NRSS Service Manual
Thanks, Sea Breeze
Aug 06, 2012 | GE Monogram ZISS480NRSS 48" Built-In...
P1494 code
Hi there:Here's a little information on it and some things to check...
For more information see if you can get a copy of this Technical Service Bulletin from your local Mitsubishi dealer.
NO.: TSB-98-13-012
DATE: September, 1998
MODEL: 1996-97 Eclipse 2.0L Non-Turbo
SUBJECT:
Evaporative Emission Control Leak Detection System Diagnosis
PURPOSE:
This bulletin describes the operation of the evaporative emission control leak detection system and how to diagnose diagnostic trouble codes (DTCs) relevant to this system (DTCs 183, 184, 187, 160, and 161).
I think the whine you hear while turning the steering wheel is a P/S system that's low on fluid or a P/S pump starting to go bad.
The rattle under the dash could be anything from loose change to a loose component.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 31, 2012 | 1999 Mitsubishi Eclipse
I have a P0456 code on my 2003 Ford Expedition. Where is the vapor purge solenoid or the canister?
The information you are asking for varies depending on how the vehicle is equipped ie. ENGINE SIZE, AUTOMATIC or MANUAL TRANSMISSION, 2-WHEEL DRIVE, 4-WHEEL DRIVE, ALL-WHEEL DRIVE, etc.
With that said, it also deserves mention that there is a Technical Service Bulletin published by Ford Motor Company that applies to the model year and model that you have listed that involves Diagnostic Test Code (DTC) P0456.
Please note that this bulletin emphasizes the requirement of special equipment to properly diagnose and repair the DTC's listed in the bulletin. Below is a brief (partial) description of the bulletin:
Article No.
03-20-3
10/13/03
DRIVEABILITY - MALFUNCTION INDICAOR LAMP
(MIL) ILLUMINATED WITH DTC'S P0442, P0455,
P0456, P0457, P1442 OR CHECK FUEL CAP LAMP
ILLUMINATED WITH DTC P0457
FORD: 1997-2000 CONTOUR 1997-2002 ESCORT 1997-2003 CROWN VICTORIA, MUSTANG, TAURUS 1998-2003 ESCORT ZX2 2000-2003 FOCUS 2002-2003 THUNDERBIRD1997 F-250 HD
1997-1999 F-250 LD
1997-2003 E SERIES, EXPEDITION, EXPLORER, F-150, RANGER, WINDSTAR
1999-2003 F SUPER DUTY
2000-2003 EXCURSION
2001-2003 ESCAPE, EXPLORER SPORT TRAC, EXPLORER SPORT
LINCOLN:
1997-1998 MARK VIII
1997-2002 CONTINENTAL
1997-2003 TOWN CAR
2000-2003 LS
1998-2003 NAVIGATOR
2002-2003 BLACKWOOD
MERCURY:
1997-1999 TRACER
1997-2000 MYSTIQUE
1997-2003 GRAND MARQUIS, SABLE
1999-2002 COUGAR
1997-2003 MOUNTAINEER
This article supersedes TSB 03-9-8 to update the vehicle lines and Service Procedures.
ISSUE
Some vehicles may exhibit a Malfunction Indicator Lamp (MIL) illuminated with Diagnostic Trouble Codes (DTCs) P0442, P0455, P0456, P0457 or P1442 or a "Check Fuel Cap" Lamp illuminated with DTC P0457 for the Evaporative Emission System. This may be caused by loose or leaking hoses, loose or broken fuel cap, a leak at the top of the fuel filler pipe neck, etc.
ACTION
Use the Rotunda Leak Detector Smoke Machine (Part 218-00001) or equivalent, to locate and repair leaks in the Evaporative Emission System.
Oct 14, 2011 | 2003 Ford Expedition
Went on trip, drove a little over 500 miles to destination. When went from one freeway to another car seemed to go into a limp mode after slowing to bout 20- 25 mph. I reset by putting it in park turning...
PO456 is most times a gas cap or gasket,
to get an incorrect gear ratio the transmission has probably started to slip.
Change the fluid and filter first off in the transmission and use only atf+4 fluid and possibly the govenor pressure sensor,and change gas cap.
Jun 02, 2010 | 2003 Dodge Intrepid
How to access evaporator coil
I would suggest allowing an appliance service company to perform any work on your evaporator coil (which is located behind the rear panel in your freezer compartment). This coil has refrigerant inside and if damaged you will only add to whatever issues you already have.
Feb 22, 2010 | Frigidaire Freezers
1992 hyundai excel coil will not fire. everything from coil to the dis is ok. turn dis hear injectors click "jump coil with battery it fires. HELP!!
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 09, 2009 | Hyundai Motor 1992 Elantra
Refrigerators Logo
77 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
