Question about Hardware & Accessories
What is the proper wiring schematic forIntermatic AND WG1573-5
My Intermatic AND WG1573-5, ois not getting pwer to tmy water pump
  • 5,089 Answers
WG1573 is 240Volt clock motor that fits into Intermatic T100 series timers. The white wires on clock motor usually connect to terminals 1 and 3, but they can be moved to accommodate different wiring objectives.
Copy following links to determine cause of problem, and see correct wiring for T100 series timers
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment and say if this is new timer, or older timer that stopped working. Describe the timer, including how many screw terminals and where the wires are connected. Include voltage of pump that shows on pump label, and describe the circuit breaker controlling circuit.
Gene
Posted on Jul 22, 2013
How to connect my well pump to timer
T8845PV has 120 volt input.... but 24Volt output,
You can use 24 volt to control contactor that can be used to switch 120-240 volt pump
Wiring on following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Dec 02, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Can't get timer to work. Wires R red, blue,green. Is red hot, blue neutral?
You should've fixed your Intermatic timer for $20 with new clock motor or trippers.
GE 15306 is 120Volt timer.
You probably have 240Volt power to pump.
Copy following links to help solve problem, and repair the Intermatic timer so you can return the GE for refund at Home Depot.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Aug 21, 2012 | Hardware & Accessories
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
My timer for my water feature looks like your Intermatic T101R3 timer. I do not have an instruction manual. Can you e-mail me some simple instructions for using this so I won't get charged an...
T101R3 is outdoor pool timer with fireman's switch.
Some are double-pole, some are single pole, some are 240V and others are 120V.
They each look like the other so eyeball identification is not enough information.
The model number should be inside door of timer.
http://www.poolandspacontrols.com/products/mechanical%20time%20switches/pool%20and%20spa%20time%20switches.aspx
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
I have been unable to locate manual specific for these products, and I have looked.
I was looking yesterday for this instruction manual.
Some wiring diagrams appear on following page, but again it depends on your specific model
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The T101R series is designed to control pool pump and pool heater.
Fireman's switch automatically turns off pool heater 20 minutes before pool pump is scheduled to turn off.
So you set the trippers on dial, and then the fireman's switch does the rest automatically.
Add a comment with in-focus photo of inside of timer door and I can put together all the information and simplify instructions. Put your digital camera in 'macro' with the flower-symbol to take close-up photos. Photo has to be in focus so I can read information and see wiring schematic.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 20, 2011 | Hardware & Accessories
How to wire an intermatic eh40 water heater timer in simple terms
Don't know how to get more simple then the wiring straight from Intermatic...
Here is the link to the manuals for your timer...
heatman101
Sep 18, 2010 | Intermatic EH40 - Electronic Water Heater...
I have an Intermatic pool pump timer. The motor for the clock is running, but the on of switch will not trip. I made sure the stop/start pins are properly on. I did recently replace the switch below for...
If the motor doesnt have enough power to trip the switch you will have to replace it. The motor assembly is replacable without having to replace the whole box. I know you can get them at Lowes and Home Depot.
Sep 25, 2009 | Intermatic T104 24h 208-277v Mechanical...
Wiring a wh40 intermatic timer to a sears hot water heater
Shut off breaker to you water heater. STILL TEST FOR VOLTAGE BEFORE YOU TOUCH ANY WIRING. The 3 wire that go to you water heater disconnect them. You are going to install them to your WH 40 timer.
The wires that you disconnected will now go to terminals: Black to Terminal 1 & White To Terminal 3, The Ground copper wire will go to the ground terminal should be a green screw.
You will have to buy some 10/2 wiring to go from your timer to your water heater. You can buy it by the foot at Lowes. Figure how much you will need.
With the new 10/2 wire install the Black to terminal 2 & White To Terminal 4, the ground wire will go to the ground screw with the other ground wire.
Wiring that went to terminals 2 & 4 will be installed to you water heater, the same way when you disconnected them. Set your timer clock and your done. Turn breaker back on!
Dec 28, 2008 | Intermatic WH40 - Water Heater Time Switch...
Hardware & Accessories Logo
62 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
