Question about Toro BODY-THROTTLE Part 117-4915
Throttle body sensor installation
Is it possible to install the sensor upside down? Installed new one and the truck will start up but not stay running. its like it is getting no gas.
  • 458 Answers
If you are referring to the MAF(Mass Airflow Sensor),it will cause this exact problem if it is installed backwards.(I see many car build shows,and they get it wrong so much,I thinks they are doing it on purpose to make the show more interesting).
Posted on Jul 28, 2013
Throttle positing senser on a 99ranger I changed it now the idle is way to high
The positioning of the new TPS IS OFFSET....It is possible to install it wrong by accident..I have seen this happen before..The pressure from the sensor plastic actuator has been installed and slightly twisted against the throttle lever inside which causes throttle to raise slightly....Wear safety glasses and disconnect battery..Remove sensor slowly and carefully while removing and watch the throttle lever inside to see if it moves in any direction...Carefully install it again making sure it doesn't twist the throttle lever inside where sensor mounts...The lever on the sensor should stay in its position...Carefully install sensor making sure it doesn't twist...Connect wiring and battery and start for a safety check.....It is possible to have a wrong sensor or faulty new sensor...Double check that it is the correct sensor...
Mar 01, 2015 | Cars & Trucks
My 95 chevy Tahoe wont stay started after I installed a water pump
Vent the Top hose , Possible Air lock and overheating , Check thermostat
Jan 28, 2015 | 1995 Chevrolet Tahoe
How to replace the TPS.
no engine option stated, and is key fact to know here.
eg:
The 5.7L V8 engine does not use a separate Throttle Position Sensor (TPS) on the throttle body.
remove old TPS, and bolt on new.
its like 2 or 3 screws. no big deal.
but needs to be calibrated per fsm.
ill take a wild guess, 3.7L
3.7L Engine and 4.7.
  1. Remove air resonator tube at throttle body.
  2. Disconnect TPS electrical connector.
  3. Remove two TPS mounting screws.
  4. Remove TPS.
install
The throttle shaft end of throttle body slides into a socket in TPS. The TPS must be installed so that it can be rotated a few degrees. (If sensor will not rotate, install sensor with throttle shaft on other side of socket tangs). The TPS will be under slight tension when rotated.
  1. Install TPS and retaining screws.
  2. Tighten screws to 60 inch lbs. (7 Nm) torque.
  3. Connect TPS electrical connector to TPS.
  4. Manually operate throttle (by hand) to check for any TPS binding before starting engine.
  5. Install air cleaner tube to throttle body.
some TPS need calibration
to see what yours needs, read the FSM
or at alldata.com
or here. I think all engines here, are TPS PCM autocalibrated.
read WJ car here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
May 24, 2014 | 2005 Jeep Grand Cherokee
Engine stalls under acceleration, shows code P1580, changed throttle body with new one but problem persists
I would worry or be concerned about the code.
The code is about the throttle sensor or actuator. If the sensor is faulty or the computer is not getting a good signal from the sensor it does not know what the throttle position is.
You might try resetting the throttle position - clear the code, key on but don't start, hold pedal to the floor, key off.
Aug 25, 2012 | Cars & Trucks
Where is the throttle positions sensor located
The Throttle Position Sensor, or TPS is connected to the throttle shaft on the throttle body.
Fig. 2: Disengage the Throttle Position Sensor (TPS) wiring harness connector
According with the Grand Cherokee Repair Manual, check this removal & installation procedure...
(see Figures 5 and 6)
  1. Remove the air intake tube at the throttle body.
  2. Disengage the TPS wiring connector and remove the two mounting screws.
  3. Carefully remove the TPS from the throttle body.
To install:
  1. The throttle shaft end has a tang that can be fitted into the TPS two different ways. Only one of the installed positions is correct. When correctly positioned, the TPS can be rotated a few degrees. To determine correct positioning, place the TPS onto the throttle body with the throttle shaft tang on one side of the TPS socket. Verify that the TPS can be rotated. If the TPS cannot be rotated, place the TPS on the throttle body with the throttle shaft tang on the other side.
  2. Tighten the two TPS mounting bolts to 60 inch lbs. (7 Nm) and engage the wiring connector.
  3. Manually operate the throttle and check for any binding.
  4. Install the air intake tube.
Fig. 5: Remove the throttle position sensor retainers...
Fig. 6: ...then, remove the throttle position sensor
Additionally, its possible that you are interesting in some section about this repair manual: Jeep Grand Cherokee 1993-1998 (ZJ Series).
Hope this helps; just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment. Thank you for using FixYa.
Jose.
Oct 20, 2011 | 1997 Jeep Grand Cherokee
When i turn on heater or fan engine revs over 3000 rpm
Idle Air Control Valve Pintle may be bad If you disconnect the IAC and the problem ceases it can point to this being the problem.: Removal & Installation 3.5L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the fuel injector sight shield.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • The air cleaner intake duct. Figure of IAC and TPS electrical connectors disconnected. aurora_g1.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of cruise control and throttle control cables removed from throttle lever. aurora_g2.gif
    • The cruise control cable and throttle control cable from the throttle body lever.
    • The fuel pressure regulator vacuum hose, positive crankcase ventilation (PCV) hose and the throttle body vacuum port hose.
    • The throttle body coolant hoses.
    • The throttle control cable bracket, leaving the throttle and cruise cables connected.
    • The upper nut holding the throttle body to the intake manifold.
    • The throttle body assembly.
  5. Clean the gasket mating surfaces.
To Install:
  1. Install a new gasket and new studs if necessary.
  2. Install or connect the following:
    • Start the top nut by hand.
    • Position the throttle control cable bracket and hand start the retaining nuts and bolt.
    • Torque the three throttle body retaining nuts to 89 in.lbs. (10 Nm). And the bracket retaining bolt to 115 in.lbs. (13 Nm).
    • The throttle body vacuum port hose, PCV valve hose and the fuel pressure regulator hose.
    • The throttle control and cruise control cables to the throttle body lever.
    • The IAC valve and TP sensor electrical connectors.
    • The air intake duct.
  3. Refill the cooling system.
  4. Install the fuel injector sight shield.
4.0L Engine To Remove:
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable.
    • The Mass Air Flow (MAF) sensor electrical connector.
    • The PCV valve fresh air tube. Figure of cruise control cable removed from throttle cable bracket. aurora_g3.gif
    • The cruise control cable and throttle control cable from the bracket.
    • The cruise control cable and throttle control cable from throttle body lever. Figure of IAC valve and TPS connectors removed. aurora_g4.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of fuel lines removed from retainer on throttle cable bracket. aurora_g5.gif
    • The fuel feed and return lines from the retainer on the throttle control cable bracket.
    • The transaxle shift cable clip from the throttle control cable bracket. Figure of throttle body removed from water crossover. aurora_g6.gif
    • The throttle body from the water crossover.
To Install:
NOTE: The Mass Air Flow (MAF) sensor inlet and the outlet of the air cleaner assembly must line up when installed. Misalignment may cause MIL illumination or driveability concerns.
  1. Install or connect the following.
    • The throttle body to the water crossover. Torque the bolts to 106 in.lbs. (12 Nm).
    • The throttle and cruise control cables to the throttle body lever.
    • The throttle and cruise control cables to the throttle control cable bracket. The transaxle shift cable clip to the throttle control cable bracket.
    • The fuel feed and return line retainer to the throttle control cable bracket.
    • The MAF sensor electrical connector.
    • The air cleaner intake duct clamp. Torque the clamp to 27 in.lbs. (3Nm).
    • The fuel injector sight shield. Torque the nuts to 20 in.lbs. (2.3 Nm).
  2. Install the negative battery cable.
  3. Pressurize the fuel system and verify no leaks.
Oct 07, 2010 | 2001 Oldsmobile Alero
3000gt sohc wants to start but wont?
With all the new parts check the tps sensor on the throttle body may be unhooked.
Sep 08, 2009 | 1997 Mitsubishi 3000GT
Lack of power
If your problems started from the day that you had the new throttle body installed, yes this may be your problem. I'll give you some checks that you may perform to check if it was installed properly.
1.Make sure that all the hoses were replaced and all hose clamps were tightened up properly, if it leaks air, your air flow sensor wont be able to read the correct air flow into the egine which leads to poor performance.
2. If it is second hand throttle body that was installed, move your throttle shaft where the accelerator cable is attached to, up and down. If there is a lot of movement you will have to replace it or get it re-bushed.
3.On the side of the throttle body is a black unit attached, this is your throttle position sensor. With the egine not running, move the throttle on the throttle body, you should hear a click sound (a micro switch inside this unit opens a circuit), if you do not hear a click sound it has been set up incorrectly. Loosen up the two bolts holding this unit to the throttle body and turn this unit in the opposite direction of the throttle to rev up the engine if it was running, then turn it in the same direction as if you would throttle the engine but do it slowly untill you can hear a click sound. As soon as it clicks hold it and tighten the lock bolts. Now test it and make sure as soon as you would accelerate it clicks, job done for this one.
Generally look for vacuum hoses that might not be connected or secured properly and or electrical connections that might not be in place.
Aug 29, 2009 | 1999 Suzuki Vitara
HELP
near the throttle body part there is a electronic idle control valve either this control valve is defect or there is a leak between the body and the valve.
regards Sam (holland Europe)
May 14, 2008 | 2003 Dodge B Series Cargo
Toro BODY-THROTTLE Part 117-4915 Logo
43 people viewed this question
Top Toro Heavy Machinery Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a Toro Heavy Machinery Expert? Answer questions, earn points and help others
