Question about Turbo Air Reach-In Refrigerator- 3 Section- 3 Solid Door- 72 cu. ft
Door lock for Turbo AIR
Turbo Air Model TSR-72SD
    New Friend:
    Problem Solver:
  • 10 Answers
Turbo Air Kegerator TBD-2SD at Kegerators.com featuring full two 1/2 barrel capacity and 3 inch diameter stainless steel insulated beer columns.
Posted on Jul 04, 2015
    New Friend:
How to remove the 3 locks from the panel. Both side of the panel are riveted. How to remove the panel to reach the 3 locks.
Posted on Jul 23, 2013
Turbo air m#TSF-72SD will not hold below freezing. Cleaned coil an temp dropped to 29 but no further...
If everything else is in proper working order, either a refrigerant level issue or and expansion device issue. If system constantly runs the previous, if not, possible temperature control. Look for system cycling or not cycling.
Jan 10, 2018 | Turbo Air Freezers
Doors do not self shut. Stays open a little bit. Can the doors be adjusted or do springs have to be replaced?
there are no springs . check to see if it is level or just slightly off lower at the back helps close the door
May 14, 2016 | Turbo Air TSR-49SD Stainless Steel...
Fridge stays at 28
Is it a fridge or freezer, and what are the symptoms, in detail? Is all working normally, just not switching off? Check condenser clear and clean, and try turning thermostat down to 1 (if mechanical) or up to 40 (if electronic)
Apr 26, 2014 | Turbo Air 72 cu. ft. / 2039 liter...
Need to replace door gaskets
Emmie,
There are two gasket options for that model! If you have your unit's serial # we can ID the exact gasket you need. Replacing your gasket is a simple process and it looks that your gasket is a simple snap in option. Here's option1 http://www.coolergaskets.com/turbo-air-gasket-25-1-2-x-53-1-4-1/ & Here's option 2 http://www.coolergaskets.com/turbo-air-gasket-25-1-4-x-53-1-4/
It looks like both gasket options are made out of the same profile material but the dimensions changed per when the unit was manufactured. Double check your existing gasket's dimensions to determine which option is the best for you. Or shoot us an email or give us a call with your Model and Serial # and we can narrow it down for you.
855-288-2259
orders@coolergaskets.com
Aug 03, 2012 | Turbo Air TSR-49SD Stainless Steel...
I have a commercial freezer and I just replaced the gasket. Its the exact fit for this model and didnt have any problems installing it. When I close the door it wont stay shut in other words the gasket...
this is happening because of the new gaskets, what you do is lay something against the door or doors overnight and tomorrow they will be great. hopw this helps.
Feb 23, 2011 | Turbo Air TSR-49SD Stainless Steel...
The left hand door is energized and shocks people when they open it. My understanding is that there are wires in the door, which power a heater. Is this heater necessary? Can the power to the door be...
Yes. The heater is there to prevent condensation. If you disconnect it you may get moisture on the glass. If you cut the wires be sure to tape them up.
Jan 29, 2011 | Turbo Air 72 cu. ft. / 2039 liter...
Leaking H2O
Behind the grille on the bottom is a drain pan. May have a crack in it.
Jun 15, 2008 | Turbo Air 72 cu. ft. / 2039 liter...
Freeze will not run doors heat nothing else
That is known as a puffed capacitor and usually indicates a power supply problem as well. The cap can be changed with a 50/50% chance to work again unless it took out other components.
Sep 14, 2007 | Turbo Air 72 cu. ft. / 2039 liter...
Turbo Air Reach-In Refrigerator- 3 Section- 3 Solid Door- 72 cu. ft Logo
89 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
