How to connect Belkin (F5D7132) with another wireless router without cable.
Guys, Is that possible to connect Belkin (F5D7132) wireless range extender with another wireless router without using cable? If yes, how to do that?
Silverblade
  • 173 Answers
SOURCE: Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Posted on Nov 05, 2008
SOURCE: Belkin w/range extenter question
you can use as many as you want, since they just find a signal and amplify it. using more than one shouldnt cause any problems
Posted on Nov 07, 2008
  • 192 Answers
SOURCE: I installed a Belkin wireless
contact apple.
Posted on Jan 04, 2009
raffaiel
  • 209 Answers
SOURCE: Hello, I currently use a Belkin F5D8631 as my Modem Router. I have a spare Belkin F5D7633. Can I use the 7633 as a repeater/bridge to extend my wireless range? If so, how?! Thank you
It will not extend your wireless range. If you connect your spare Belkin F5D7633 to your Belkin F5D8631, one of them would have to be set to "bridge mode" or a pass through modem so that there will be no conflicts as to which modem will receive the ip address from the network. If you set your modem/router to bridge mode, it would disable its wireless function because it will only be a pass-through device.
If you want some tips on how to improve your wireless range, check out this site http://www.microsoft.com/athome/moredone/wirelesstips.mspx. Hope this helps.
Posted on Apr 22, 2009
  • 451 Answers
SOURCE: can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Posted on Feb 27, 2012
I cannot connect to internet because my computer was remastered and trhe computer does not recognise my router and is telling me to install a driver
I Figure your using a USB lead from your router to your computer. You will need to download the USB interface driver from the Belkin web site. Otherwise, if the router has a ethernet jack, then use a patch cable to your computer (ethernet port) eliminating the need for a driver
Feb 15, 2011 | Belkin (F5D7132)
Can I boost signal strength?
You will need to get hold of a Belkin Wireless G Universal Range Extender relays the signals of your wireless network and extends its range model number F5D7132 from PC world or another online dealer.
You will still need the wireless router as the central connection point, using the booster your network now reaches further I have one at the top of the stairs with the Router downstairs to I can browser wirelessly in the loft conversion of my old house
Oct 11, 2009 | NetGear DG834G Wireless Router
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
Hi Druid,
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin f5d7132
For best results, you should connect it directly to the other router with an ethernet cable.
Jul 21, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Belkin wireless extender
how thick are the walls? what is the longest line of sight connection you can make?
Jul 20, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Belkin wireless G range universal extender /access point
i would look at home plug solutions:
http://www.solwise.co.uk/net-powerline.htm
Solwise are goog guys or buy from Scan computers - again good for support and returns if you have to.
Belkin - personnally would not touch them! Too many bad experiences like you.
Jul 18, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Belkin Wireless G Router in a 220v socket!
the router is most likely fried.
you could be in luck though. just get another power cable and see if that works.
Jul 14, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Setting up my wireless
first connect the router via cable with the pc.
start internet-explorer, type in http://192.168.0.1.
this ip-adress maybe different for several routers, please read manual for the correct ip.
if ip is correct you can now see the menu of the router, type in your provider datas, secure the w-lan connection (wpa if possible), write down the passphrase you choosed. deconnect router - setup now your wireless usb-stick or w-lan card or use xp-assistent...type in your passphrase - should work now.
mfg
Feb 11, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
