Question about Unknown Vitality Cyro Blaze Gel Hot/Cold Pack XL 10x12 Each
Why doesn't it run?
Check compressor and thermostat setting
Apr 19, 2016 | Blaze Outdoor Products Blaze 4.6 Cu. Ft....
Sylvania SE80094-1 hot/cold water dispenser faucets leaks.
It could be a build up of minerals from the water holding them both open. You will need to gain access to the water valves to clean their surfaces.
Jan 24, 2014 | Freezers
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot, then the temperature inside the unit may be compromised if there is a sealed system issue or a restriction in the unit. Call a professional to be safe.
Jul 26, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Mar 01, 2010 | Whirlpool Freezers
Is it normal for the outsides to get very hot
No. If you feel the sides getting hot, it usually means that the ref. isn't cold enough inside. There us either an electric heater or a pass of the hot gas from the compressor around the edges of the doors as well as the mullion between them. If they feel hot, it's too warm inside.... Check the ice cream: It's the 1st to go.
Oct 25, 2009 | Frigidaire Freezer Refrigeration White...
Beverage air model sur27 refrigerator r134a powers on but doesn't get cold. compressor doesn't get cold not sure maybe it's the relay........if and when the ploblem is solved, is it hard to get parts for...
The larger pipe on compressor should get cold. The smaller should get warm to very hot depending on ambient conditions. Parts should be available, including a universal relay kit I could hook you up with. First determine if the compressor is running. Let me know. :)
Sep 19, 2009 | Freezers
The outside of the freezer door is cold, and the surrounding floor is cold - even in the hallway outside the room the freezer is in. Can't find any obvious leaks around the door seal. The sides of the...
the # should be inside, the temp in side the freezer needs to be checked. does the thing ever shut off, if not it may need a cold control
Jun 28, 2009 | Freezers
Compressor getting hot
The compressor as well as the evaporator coils will get hot when the freezer is getting cold. Simple principle: Refrigerant gets cold and there must be an equal reaction, something getting hot. Just like the heat transfer in your car with the engine heating the radiator which dissapates the heat. hope this helps you, Rick
Apr 24, 2009 | GE Freezers
Unknown Vitality Cyro Blaze Gel Hot/Cold Pack XL 10x12 Each Logo
21 people viewed this question
Top Unknown Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you an Unknown Freezer Expert? Answer questions, earn points and help others
