Question about Maytag Dryers
Maytag ensignia TURNS ON FOR A MINUTE OR TWO THEN TURNS OFF
    Top Expert:
  • Maytag Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Posted on Jul 22, 2013
2 Suggested Answers
SOURCE: maytag ensignia electric dryer makes alot if
I had a squirrel(?) stuck in mine! I removed the lint pipe and it was really nasty. Something had chewed through the screen and climbed down the pipe to stay warm?? We live in Minnesota and it was cold as heck. Anyway, Have a shop vac ready, I hope this helps. Remove pipe at the dryer, push start a couple of times and see if anything blows out. K.J.
Posted on Jan 21, 2010
Maytag ensignia dryer drum not turning
The belt would be the first thing I would check sounds like it may have broke off.
Here is a link for parts and other causes. Maytag Dryer Drum Not Turning
Jul 14, 2016 | Maytag Dryers
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
I have a Maytag Ensignia model MAV2757 AWW. The washer basket doesn't balance, even with a small load, and turns off due to the weight being unbalanced. The springs are there and oiled, the hardware...
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
Nov 14, 2017 | Maytag Ensignia MAV2757AWW Top Load Washer
Belt replacement instructions for Maytag Ensignia model MDE4658AYW electrical dryer
Try Googling " user manual for Maytag Ensignia MDE4658AYW ". You may have to go to the Maytag web site and ask for manual. Sometimes I've had to ask for repair manual instead of user manual. Good luck.
Jul 24, 2009 | Dryers
Maytag ensignia washer...cold water settings
You need to remove the cover and check the voltage to the cold water inlet valve. Do this with a volt meter while it is set to fill with cold water. It is most likely an AC voltage that is around 24 volts. If you have voltage then the valve is most likely bad.
Feb 16, 2018 | Maytag Ensignia 3.3 cu. ft. Top Load...
Dryers Logo
104 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
