TRY TO CLEAR CODES WHIT SCANNER IF DONT CLEAR AND CAME BACK SAME CODE IS NOT A DOING YOUR SELF PROBLEM IS RELATED WHIT VVT SYSTEM MY RESTRICCION TO VVT VALVE OR CLOGED GALERIES OR BAD VALVE OR INTERNAL PROBLEM WHIT ENGINE
It can be removed whit a cloth and gasoline, but be carefull because some persons are allergic to petrolleum destillates, make a little test before, once you clean whit gasoline and remove old silicone you must wash your hands whit soap, thats all.
originally nokia phone security code is 12345, but if this security number was change it only can remove by format phone firmware, try use 12345 for code first, but if this code did not work contact nokia service center
i hope this helpful
thank you for using fixya
Hi, that is something you can do is clean your
your remote by using wood alcool ;removed the battery open the remote and remove all dust and grease, whit a qtips on the contact board and the sheet rubber wip it of whit a scottowel make sure to not dammage the contact on it. if it is not to hold that should work verry well rebuild that in place and try it
hope that help
have a nice day.....
you may have blow the engine topp. se if ther are bobbels in the overflow tank when the engine is running. if so you have to replase the topp seal.chec also the head whit penetrating marking spray.for craks.
Does it do it on all connections IE: DVD, Cabe, VCR? if it does than most likely a bad digital board in the TV. If only on one connection you see this then suspect intermittent connections to that device or a bad cable.
No replacing the water filter has noting to do whit it but you may have a problem whit your defrost system or your thermostat
Tray finding the fridge control and turn it down (less cold) if still do the same get a pro to service
