Bose sound dock broken adapter broken off - Audio Players & Recorders
  • 20 Answers
SOURCE: Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Posted on Dec 11, 2008
SOURCE: bose docking station chip broke off
I had the same problem that the ipod would onl play when I pulled it forward in the dock. Looking closely, I saw that some of the pins on the left hand side of the connector were bent forward, so I bent them back with a needle:
(ie. pushing the pins to the right, as shown here). This solved the problem for me.
If your connector is too far gone, I suggest looking to:
http://www.chargeconverter.com/shop/connector.htm
for a new connector for £3-4 or
for a whole PCB (Printed Circuit Board) replacement for £10-15.
Hope this helps...
Posted on May 01, 2009
SOURCE: I need 282490-001 part for my BOSE docking sound station.
go to Bose Center Service in your city, and they change the part. I changed today and cost is usd 85 everything.
Posted on May 22, 2010
  • 652 Answers
SOURCE: Just setting up my bose ipod dock for the first
Sounds as you have a broken unit that will need to be serviced.www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/warranty_center/index.jsp
Posted on May 25, 2010
  • 17 Answers
SOURCE: Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Posted on Mar 09, 2011
Bose troubleshooting
Sounds like it's either a problem with the connector on the iPod or on the dock. To find our which see if it works okay on another dock - if you know anybody with one our text it on a demo model in a store. Or it could also be the plastic dock adapter - take our the adapter and try docking without the adapter.
Jun 20, 2014 | Bose SoundDock digital music system...
Hi.. I have a bose wave ipod docking system.. the sound is amazing.. or was... until a few weeks back when i noticed that in order to hear my ipod... i had to tweak the ipod a little on the docking...
Are you using a voltage adapter of some kind to convert the ireland standard 220VAC to the USA standard 120VAC that this device uses? Over voltage can deplete an electronics life very quickly.
By the sound of the "thump-thump-thump" noise emitting from the device, you may have a broken ipod dock connector, or a short somewhere in the connector/wiring/device itself, or the ground has failed.
By the description of having to "tweak" your ipod to hear it, it sounds like you've slowly broken the dock connector. Check to see if it moves easily, or if you can hear anything loose.
This is more than likely fixable, but it's probably easier to replace the device than to fix a broken connector.
May 26, 2011 | Bose Battery for SoundDock Portable...
My old ipod will play in my bose dock but my new one will not...It plays in other brands at the store.
You have an old version of the Bose dock. You can go to the Bose store and get an adapter for the new I pod.Some docks come with 2-3 different type of adapter to patch the generation gap.
Mar 07, 2011 | Audio Players & Recorders
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
Bose sounddock not giving any sound. Ipod working fine through earplugs. Unhooked soundock for travel, now no sound. Tried all the resets, etc. Also, new battery in remote and it doesn't respond either????
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Jun 07, 2010 | Bose SoundDock digital music system...
Nov 17, 2009 | Bose SoundDock Portable Digital Music...
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Sounddock 1 :No sound unless I push down on the iPod
Turn the sound dock over and you will see the connection for the iPod is on a separate piece of plastic, almost looks like it has been bolted onto the main bit. It means a connection will be loose between these two parts in some way. Contact Bose to get this serviced.
Dec 11, 2008 | Bose SoundDock Digital Music System for...
 Grubhead
Grubhead
