Question about Health & Beauty
Removing Battery
How to remove old battery from braun 5550 shsver?
  • Health & Beauty Master
  • 1,625 Answers
The easiest way is to break the tabs off of the batteries. See video at link below
https://www.youtube.com/watch?v=2oAnLpvdYqQ&feature=c4-overview&list=UUc_zJiCUI8mpLyYlwCxo8IA
Posted on Aug 07, 2013
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Removing BRAUN 1775 Cutter Block
Hi Miller1292
Braun have great user manuals with good pictorial instructions on how to service your shaver. To get a copy for your shaver, go to this site
Be sure to pick one that is in English:) Thanks for using FixYa, a FixYa rating for my solution would be awesome. Cheers
regards
robotek
Posted on May 08, 2008
brector3
  • 1625 Answers
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Posted on Jan 16, 2010
brector3
  • 1625 Answers
SOURCE: I have a Braun 5550
You can repair the shaver by replacing the batteries only if the shaver still works. If the shaver no longer does anything...will not run and light does not illuminate when plugged it, the circuit board is now bad and can not be repaired.
To open the shaver, remove the two plastic screw covers on each side of the hole where the cord plugs in on the bottom of the shaver. Remove the two screws underneath. You can then slide the entire outer case off of the shaver. Be careful not to disturb the trimmer as it is extremely difficult to reattach. Inside, you will see a black inner cover. Unsnap to remove it and access the circuit board and batteries.
You will find compatible batteries at shaveroutlet.com. You need two. See link below for item and scroll down for helpful installation video
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Aug 02, 2011
How to remove battery for a Braun 5311 electric shaver
You will need to remove the two round screw covers on the bottom by prying them out. Remove the pivoting head by removing two tiny screws. Once screws are removed, you can separate the front and back cases.
The correct battery type can be found at shaveroutlet.com here:
https://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Sep 23, 2017 | Braun Health & Beauty
I have a Braun 5550 electric razor that no longer holds a charge. i believe the battery can be replaced but I cannot see how to remove the battery. Can you advise?
Aug 02, 2011 | Braun Flex Integral 5550 RB Electric...
Need to know how to remove the case to replace the batteries on the braun 5441 electric shaver
First, remove the foil and cutter. Then remove the swivel frame by removing the two tine screws, Next, remove the two scew covers on the bottom. These are found on either side of the plug recepticle and look like part of the trim. You can pry them off with a small flat jewelers screwdriver or similar. Remove the screws underneath. You can then gently pry the front of the case off from th bottom. Once case is removed, you can lift out the circuit board to access the battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find compatible battery type at shaveroutlet.com. See link below
Jan 13, 2011 | Braun Flex Integral 5441 Electric Shaver
I need to replace the battery in my Braun 5414 shaver. Thanks John Lennard
First, remove foil and cutter. Then remove the swivel frame by removing the two tiny screws. Then pop off the two screw covers on the bottom of the shaver and also the screws underneath. You can then gently pry the two halves of the case apart at the bottom to access the insides.
Dec 03, 2010 | Braun Health & Beauty
How do you get at the batteries in a Braun 4501 shaver? thanks
You will find replacement battery at shaveroutlet.com. See link below
Start by removing the foil and cutter. Then remove the swivel frame by removing the two tiny screws on each side of the inside of the swivel frame.
To open the shaver you will first need to remove the two round screw covers on the bottom. Then remove screws. You can then gently pry the two halves apart from the bottom
Oct 02, 2010 | Braun 4501 Electric Shaver
How do you open a Braun 5314 Shaver to replace batteries?
Sep 30, 2010 | Braun Flex Integral 5314 Electric Shaver
Not shaving close enough.
This problem is usually cause by a worn out shaving head (foil and cutters). Braun suggests that you change these every 12-18 months for best performance. You will find replacements at shaveroutlet.com for your model 4501 Braun shaver. See link below.
http://shaveroutlet.com/foil-cutter-fit-braun-4000-series-flex-control-twin-control-p-146.html
It is also possible that your shaver is running too slowly due to an old battery if you've never replaced it. If you require a new battery, it can also be ordered from shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change the battery you will need to be able to do a little soldering. Open the shaver by removing the two round screw covers on the bottom of the shaver and then the screws underneath. You will also need to remove the foil and cutters and then the swivel frame which is attached by two tiny screws. Once removed, you will be able to open the shaver from the bottom and seperate the front and back. Remove the circuit board to easily get to the battery.
Note: The tabs on this type battery will work for most applications however they may be slightly different than some original equipment. For these instances, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
Feb 19, 2010 | Braun 4501 Electric Shaver
5550 not powering on
was the battery a exact replacement to the one you removed?
also do you have the power adaptor for it put the old battery back in and see if it will run off the adaptor with the old battery plugged in and then you know the issue is with the new battery and not the unit itself.
Sep 16, 2008 | HP iPAQ H5555 Pocket PC
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
