Computer keeps restarting
This message has come up after using the Recovery Disc. File name{546 output error file to the following location: A:\viewerr.ERR. I hit OK than this message came up. Cannot open viewerr.ERR-insert diskette 434.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
The system need to be reinstalled or fixed by experienced technician. But you can try to do Recovery again, choosing Advanced options, to see where is the problem.
Posted on Jul 21, 2013
5 Suggested Answers
Crashster
  • 181 Answers
SOURCE: Qosmio g15 recovery disk error
If the discs are clean and pretty much scratch free, then this is most likely a bad hard drive. If you have another PC or laptop, try burning copies of the recovery cds and then use those. If the problem remains, you will need a new hard drive.
Posted on Dec 10, 2007
DarkmanUK
  • 94 Answers
SOURCE: Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Posted on Aug 11, 2008
  • 461 Answers
SOURCE: Can't Uninstall Lenovo Rescue and Recovery
The exe file you downloaded is a self-extracting package - you need to run it to extract the files.
Posted on Dec 27, 2008
md_ehsan_1
  • 255 Answers
SOURCE: Cannot Reformat Toshiba Satellite P200 using the Recovery P200
1. after recovery is done, you dont find sound on your machine
2. no problem, download the Pcwizard 2008 from the given link
save it & install it in your computer, it will give you your all
devices name and model number...
3.http://pc-wizard-2008.en.softonic.com/download#pathbar
4. note down your device name and model number and download
the drivers from the given link.
5. http://www.lostmydrivers.com/soundcard-drivers/realtek/
Note:-
If you want to Re-install your OS you can re-install and follow the above steps, hope you will solve your problems.
all the best.. try it..
Posted on Jun 21, 2009
Can I dl or burn to disc the factory reset for my gateway nv5105u laptop? I have lost that CD
If you have lost the CD you can try to do a factory reset from the recovery partition. Make sure you haven't formatted or deleted any partition in the computer since your purchase.
Using the Recovery Partition to perform Recovery.
First turn off your computer
Turn on the system and keep tapping the F11 key
system will boot into recovery partition. Follow the instructions below:
  1. Boot into Gateway System Recovery - Press F11 to Start Recovery.
  2. On the System Recovery Menu screen, press the ALT+D keys.
  3. At the command prompt, type: D: and then press ENTER.
  4. At the D:\ prompt, type: CD Windows\i386 and then press ENTER.
  5. At the C:\Windows\I386 prompt, type: dir filename.* and then press ENTER.
  6. Verify if the file name has an underscore ( _ ) in the extension. Example: appwiz.cp_. If the file has an underscore, it has to be expanded. If it does not have an underscore, the file can be copied without expansion.
  7. If file has an underscore, expand the file to the destination. At the command prompt, type: Expand filename.**_ C:\Destination. Example: Expand appwiz.cp_ C:\Windows\System32
  8. If file does not have an underscore, copy the file to the destination. At the command prompt, type: Copy filename C:\Destination. Example: Copy atmadm C:\Windows\System32
  9. At the command prompt, type: Exit.
  10. Once back at the menu, click Quit. The computer restarts.
It should be reset to Factory settings.
IF YOU DO NOT HAVE ANY RECOVERY PARTITION OR HAVE DELETED THE PARTITION THEN PLEASE REVERT SO THAT I CAN HELP YOU TO GET A RECOVERY DISC.
Thank you for using Fixya..!!
Aug 05, 2012 | Gateway nv5105u Notebook
Tip
"Could not start the Remote Procedure Call (RPC) Service. Error 1058"
Issue: "Could not start the Remote Procedure Call (RPC) Service. Error 1058" error message when you manually start the Remote Procedure Call service Resolution :
1 . Restart your computer by using the Safe Mode startup option. To do this, follow these steps:
a. Restart your computer, and when the Boot menu appears, press F8 .
b. Under Windows Advanced Options Menu, select Safe Mode, and then press ENTER .
c. When the Boot menu appears again with the words "Safe Mode" displayed at the bottom of the menu, select the operating system that you want to start, and then
press ENTER.
2 . Click Start, click Run, type regedit, and then click OK.
3 . In the left pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Hardware Profiles\Current\System\CurrentControlSet\Enum\ROOT\LEGACY_RPCSS
4. On the File menu, click Export.
5. In the File name box, type a name for the registry file.
6. In the Save in list, click the location where you want to save the registry file, and then click Save.
7. Right-click LEGACY_RPCSS, click Delete, and in the Confirm Key Delete dialog box, click Yes.
Note Do not delete any one of the following subkeys that may be found under the ROOT subkey:• MS_L2TPMINIPORT
• MS_NDISWANIP
• MS_PPPOEMINIPORT
• MS_PPTPMINIPORT
• MS_PSCHEDMP
• MS_PTIMINIPORT
8. Exit Registry Editor.
9. Restart your computer by using the Restart Windows Normally startup option.
on May 30, 2008 | Microsoft Windows Vista Home Premium with...
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
      Add installation to boot list? (Yes/No/All)
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Apr 13, 2010 | Computers & Internet
Ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Jul 07, 2009 | Compaq Evo D500 PC Desktop
Continuous BLUE SCREEN after sp2 install.
After you upgrade your computer to Windows XP, you might receive the following Stop error message when the computer starts: STOP: 0x0000007E (0xC0000005, 0x804E518E, 0xFC938104, 0xFC937E04)
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
WUSB54GCx86.sys- Address 92D89498 base at 92D7c000, Datestamp 45c04cc9 Note The parameters and file names in this error message might vary, depending on the cause of the Stop error. The file name in the second line of the error message, WUSB54GCx86.sys, is an example of a driver file that might be causing the error.
This article discusses seven methods for resolving the problem. The first method is designed for beginning to intermediate computer users. The other six methods are designed for advanced computer users.
Because this article contains steps that involve restarting your computer, you might find it easier to follow the steps if you print this article first.
CAUSE
This issue might occur if a system thread generates an exception that the error handler does not catch. This exception can be caused by any of the following: • If this issue occurs after the first restart during Windows Setup or after Setup is complete, the computer might not have sufficient hard disk space to run Windows XP. • The computer BIOS might be incompatible with Windows XP, or it might have to be updated. • The video adapter drivers might be incompatible with Windows XP. • A device driver or a system service might be damaged. • If the issue is associated with the Win32k.sys file, it might be caused by a third-party remote control program.
Use the Windows Error Reporting tool loadTOCNode(2, 'resolution'); You can use the Windows Error Reporting tool to send information about the error to us and to obtain information about any available fix or workaround. Follow these steps to use the Windows Error Reporting Tool: 1. When the Windows Error Reporting window pops up on your computer, click Send Error Report to send the error report to us. 2. In the confirmation window that appears after you send the error report to us, click More Information. This helps you find any available fixes for the problem or information about how to work around the issue. 3. If a fix or a workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue. If you are not comfortable with advanced troubleshooting, you might want to contact Support. For information about how to contact Support, visit the following Microsoft Web site:
Method 1: Make sure that you have sufficient hard disk space loadTOCNode(3, 'resolution');First, make sure that you have sufficient hard disk space. The Stop error can be caused by insufficient hard disk space.
If you can use safe mode or the Recovery Console to start the computer, delete any unnecessary temporary files, Internet cache files, program backup files, and files that contain saved file fragments from disk scans (.chk files). You can also install Windows XP on another hard disk that has more free space.
If you cannot start the computer, go to the next method to update the computer BIOS.
Method 2: Update the computer BIOS loadTOCNode(3, 'resolution');If freeing space on your hard disk did not resolve the problem, the BIOS might have to be updated. Use the hardware and software vendor contact information articles that are listed in the "References" section to contact the computer manufacturer to obtain the most recent BIOS update.
Note When you update the BIOS, you might have to disable BIOS memory options, such as caching or shadowing, temporarily.
Method 3: Disable or update device drivers loadTOCNode(3, 'resolution');If you have updated the BIOS successfully and the problem persists, the video adapter drivers on the computer might have to be updated or disabled. Follow these steps to troubleshoot the video adapter drivers: 1. If a driver is listed by name in the Stop error message, disable or remove that driver. • If the error occurs during the startup sequence and the system partition uses the NTFS file system, you might be able to use safe mode to rename or to delete the faulty driver. • If the driver is used as part of the system startup process in safe mode, you must use the Recovery Console to start the computer. 2. If the Stop error message does not indicate a specific driver, update the video adapter drivers to the latest versions. 3. Disable or remove any drivers or services that you recently added. 4. Check the Microsoft Hardware Compatibility List (HCL) to determine whether the PCI devices in the computer are compatible with Windows XP. For information about the HCL, visit the following Microsoft Web site:http://www.microsoft.com/whdc/hcl/default.mspx
Method 4: Remove unsigned driversIf you have updated the video adapter drivers and the problem persists, or if you cannot start Windows in safe mode, the problem might be caused by a different, unsigned driver. Remove all drivers that are not digitally signed by Microsoft. For more information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base:
316434 (http://support.microsoft.com/kb/316434/) How to perform advanced clean-boot troubleshooting in Windows XP
Method 5: Remove all third-party drivers loadTOCNode(3, 'resolution');You might be unable to determine which third-party driver causes the error. If removing unsigned drivers does not resolve the issue, try moving all third-party driver files from the %Windir%\System32\Drivers folder to a different location. Follow these steps to move the third-party driver files: 1. Use the Recovery Console to start the computer, or start the computer from a different installation of Windows if you have performed a parallel Windows installation. 2. Create a temporary folder to hold the driver files. For example, you could create c:\DriverTemp. 3. Move all files that do not have a creation date for Windows XP of 8/13/2001 from the %Windir%\System32\Drivers folder into the temporary folder that you created in step 2.
Caution If the computer relies on third-party IDE or SCSI controller drivers for correct operation, you must identify those driver files and then leave them in the %Windir%\System32\Drivers folder. 4. Restart the computer. 5. Continue the Windows Setup program. You can add the driver files back to the computer one at a time to identify the faulty driver.
Method 6: Remove third-party remote control servicesIf you still have the problem after you use the previous methods and the Stop error message contains the Win32k.sys file name instead of a driver file name, the problem might be caused by a third-party remote control program. To remove the service, use the Recovery Console to start the computer and then delete the third-party remote control service file.
Oct 24, 2008 | Intel Motherboard
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
Missing file or corrupt
Method 1 loadTOCNode(2, 'resolution'); Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 3 loadTOCNode(2, 'resolution');
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
uparrow.gifBack to the top Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Jun 23, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
"File not found" error message when I try to use a saved network settings file to
CAUSE This issue may occur if you change the file name from the default file name "Networksettings.xml". RESOLUTION To resolve this issue, do not click My settings are on a floppy on the Where are your network settings located? page in the Microsoft Broadband Networking Setup Wizard. Instead, click My settings are in a file available from this computer, locate the floppy disk drive, and then click your configuration file.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
"File not found" error message when I try to use a saved network settings file to configure my Microsoft Broadband Networking hardware
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
