Question about Crafts & Hobbies
Repair manual truck after driving shuts off after short distance and willrestart after 5 minute wait. when truck shuts off engine just turns over if out of gas
  • 740 Answers
SOURCE: ENGINE SHUTS OFF
Have the code check and get back to me. You can go to Auto zone and they will check it for free. Good Luck
Posted on Dec 15, 2008
  • 112 Answers
SOURCE: 2004 Pontiac Grand Prix Engine Problem
sounds like a crank sensor, my cousin had the same problem
Posted on Dec 25, 2008
  • 6 Answers
SOURCE: won't start after driving short distance
I would check any recalls.   I had a 2000 Nissan Sentra and the crankshaft position sensor was the problem.  It may be a warranty replacement item.
see this
http://nhthqnwws112.odi.nhtsa.dot.gov/acms/docservlet/Artemis/Public/Recalls/2007/V/RCDNN-07V527-8115.pdf
Posted on Apr 30, 2009
  • 174 Answers
SOURCE: RUNS FOR 20 MINUTES AT FIRST THEN SHUTS DOWN, THEN
Have you checked the oil level?
Posted on Jul 17, 2009
canbruce75
  • 1776 Answers
SOURCE: engine shuts off while driving
I would suspect a faulty EGR valve, but is the check engine light on? If it is, take the vehicle to an autoparts store and have them use a scan tool to retrieve the fault code(s) stored in the computer. Most parts stores offer this service free of charge. That will narrow the search for the problem. Sure hope this helped.
Posted on Jul 20, 2009
Where is the crank position sensor located?
its not your crank positioning sensor. all the CPS does is control your spark plugs up to around 500 rpms (while trying to start) once started the ECM takes over that function in conjuction with your cam position sensor
Mar 15, 2012 | 1996 Saturn SW
1991 Dodge Shadow. When its warmed up and im driving it around, the engine just shuts off. I pull over, try to start it again and it wont turn over. So i wait 5 minutes and it'll start but 5 minutes later...
this is a typical Coolant Temp Sensor issue. the part is about $20 and can be done in a few minutes. I can further help if i knew which engine was in the car.
Apr 22, 2011 | 1991 Dodge Shadow
My cirrus dies after driving about 5 miles and then dies. If I wait 5-15 minutes I can restart it and go a short distance 1- 2 miles and then repeats Thanks Jim repair center replaced crank sensor and no...
change the fuel filter.The engine is running out of fuel & possibly the fuel line is experiencing vapor lock due to insufficent gas.Hope this helps you & good luck!
Aug 19, 2010 | 2000 Chrysler Cirrus
Well i was trying to see why is my car cutting off everytime i try and start it.????
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 02, 2010 | 1994 Ford Taurus
1998 CHEVY BLAZER STARTS FIRST TIME WHEN DRIVEN FOR SHORT DISTANCE AND ENGINE IS TURNED OFF IT WONT RESTART AGAIN UNTIL YOU WAIT FOR 5 TO 10 MINUTES THEN STARTS RIGHT UP HAVE HAD THE IGNITION SWITCH...
You might want to look at your fuel pressure. Test the pressure cold, turning the key on before starting it and then when it is hot,
You could also have a coil that is not putting out spark when it gets too hot. The engine gets hotter when you shut it down because the water is not being circulated. Once the vehicle is shut down the temp increases for a while. It could also be an ignition modual, sometimes just before total failure they quit working when they get hot.
As you can see there are a lot of things that can cause this and it makes it hard for a repair shop to diagnose with out having it for enough time to duplicate the problem.
If you want to try yourself, you will need at least a fuel pressure Gage.
Hope this helps
Aug 20, 2009 | 1998 Chevrolet Blazer
Shuts down after a short drive
sounds like plugged catalytic converter for the exhaust
Aug 08, 2009 | 1995 Jeep Grand Cherokee
ENGINE SHUTS OFF
Dec 15, 2008 | 1999 Isuzu Trooper
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
