Question about Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7
Water drain Is there a drain hose assembly available?
HLP021-wm fills with water, goes thru wash cycle, then rinse and spin lights keep blinking and the water stays in the tub. It stayed that way for several hours until I unplugged it,tipped it over and...
Hi.
A common reason for long or no drain for blockage at the drain hose and check setting of the drain hose. If the hose is blocked or incorrectly set drain may not complete. See page ten of user manual about hose setting. Here the user manual.
If the hose is OK the problem is either water level switch or blockage at drain pump.Water level switch is located in control panel assembly. the part is a plastic disk connected to a long thin rubber hose that goes inside the tub. If the hose is dirty the switch will not detect drain is complete and drain will not finish. The pump is located at the bottom of the appliance. The hose connected to the pump may be blocked. In some case the pump itself may be defective.In that case the pump must be replaced. The parts for this unit are not expensive.
Parts can be ordered from Haier. Here the US website: Welcome to Haier America
Parts for this washer are also available here
Haier also makes available a service manual. Exploded view is not included.
The exploded view and part list are shown in the manual available here (Please download the manual and check pages 16-17 - a free subscription is required).
Regards.
Ginko.
Nov 21, 2011 | Haier Washing Machines
Hi I have an Bosch SGs43c02gb/35 and it does not drain all of the water out when it has finished the cycle, I have cleaned the filters out which were relatively clean and run it with a dish washer cleaner...
Hello
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Aug 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Would like to have 10 ft water supply and drains hose assembly. Is something like that availalble ?
Yes. Two ways to do it. I would use burst proof hoses first of all (the stainless braided style) I have seen lengths to 12' or couple 2 6 foot hoses with a threaded hose coupling. The drain hose is availible to any cut length at Home Depot or Lowes. Does not have to be the corregated plastic one , but one that is more kink proof the soft vinyl hose. Measure the ID (Inside diameter) to match up. Make sure you support the drain hose over that long distance since the drain water may weigh it down. Good luck!
Jun 22, 2010 | GE WSKS2060WWH Top Load Washer
The water is not draining? how do i fix it model # mdb7100awb serial# 27721893zq 5.5 amo heat 6.o amp
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for a blockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
If all the rest is OK, test and eventually replace timer board.
Parts and diagrams available here.
Nov 14, 2009 | Maytag MDB7100AWB Dishwasher
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
dishwasher_pump-repair-kit.jpg Pump Assembly
dishwasher_belt.jpg Belt
dishwasher_timer.jpg Timer
dishwasher_motor.jpg Motor
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
How do I correct the Ld from flashing
"Ld" Is for long drain, its taking longer than 5 minutes for your machine to drain. There might be a clog in the drain line.
Nov 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer not draining
a lot of GE washers use a separate motor/pump assembly that is supposted to drain the tank before it spins. That motor is not very strong and can stall if it gets a little clogged with hair or lint or cloth threads. My dad's did that from tassels from a bed spread that fell off in the wash. You can take the front cover off with a knife blade to push the lock clips in so the cover pulls off.
when you do that you can remove the hoses to the pump and pull the clogged material out.
Nov 07, 2009 | GE Washing Machines
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer wont drain
The washer's pump unit has stopped working. It may not me getting the signal to pump after the wash cycle (controller problem) or the pump has let go and needs to be replaced.
Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer is not draining during the spin cycle
not draining your washer at all, pump may be bad or no power to pump, take the drain hose out of the "stand-pipe" where water enters the sewer drain, and lower to floor and see if water drains by gravity if only slowly your pump or hose may have a slug of crud in it blocking drainage to sewer pipe
Aug 02, 2009 | GE WJSR4160DWW Top Load Washer
Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7 Logo
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
