Question about Microwave Ovens
Siemens ceran 669260 - Microwave Ovens
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
I have lost my user manual for my Siemens surpresso s 40 . Where can I downloud one ?
You can download it from here.
http://www.siemens-brand.info/siemens-surpresso-s40-manual.html
Jul 20, 2011 | Microwave Ovens
Good morning we are staying in a house of friends who are on holiday. I would like to clean the Bosch Ceran top but I am not sure which cleaning stuff I can use. Is the use of CIF creamer allowed with a...
Harry -
I would first see if your friend has a special ceramic cleaner in his or her cleaning supplies cupboard. If you can't find a ceramic cleaner, the best thing you can do is use hot water to clean the surface. All-purpose cleaners (like Cif) can damage the ceramic glass so it's best to avoid using them.
Also, look in your friend's cleaning supplies cupboard for a metal razor scraper. Use the razor scraper to scrape off any burnt-on food or spills. Do this by holding the scraper at approximately a 30 degrees angle to the cooktop while wearing an oven mitt to protect your hands. If no scraper is available, don't resort to a knife or abrasive sponge as these could damage the ceramic glass.
When the cooking surface is cool, apply a few dabs of the ceramic cleaner (if you found it) in each burner area and work the cleaning cream over the cooktop surface with a damp paper towel. Then wipe down with water and dry with a clean paper towel.
If no ceramic glass cleaner is available, it is sufficient to wipe down with hot water and a soft sponge. Never use abrasive sponges or scouring pads on ceramic glass cooktops. Also watch out for corrosive cleaners such as over sprays, cleaners containing chlorine or ammonia and stain removers - these will just further damage the surface.
For a list of approved CERAN cleaners see here: www.schott-ceran.com
Oct 28, 2010 | Microwave Ovens
Microwave Ovens Logo
63 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
