Question about Dacor ECS127 Epicure Electric Single Oven
Dacor discovery double oven error code u50 latch/door
Krazytech
  • 725 Answers
SOURCE: Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
Posted on Aug 31, 2007
vitg55
  • 70 Answers
SOURCE: Dacor CPS 130 oven will not heat
This model actually made this way. Sometime you can not see the thermostat because of the bracket in front of the door latch. When you remove grill panel under control panel you gonna see this bracket. It pulls out very easy. Behind the door latch you will see thermostat with red button on the middle. Before resetting this button make sure you disconnect electricity.
Posted on Dec 18, 2008
vitg55
  • 70 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
localwonder
  • 6784 Answers
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
Schematic wiring for epicure double oven eo230sch
Hi I found the schematic and a whole lot more here: http://www.msaworld.com/wp-content/uploads/sites/3/2014/07/Dacor-Technical-Manual-All-Products.pdf
Sep 19, 2014 | Dacor EO230SCH Discovery Epicure 30"...
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
F8 alert. What does this mean? The clock and "cancel" buttons work, but no heating buttons work, and self-clean will not operate.
F8 code means your door latch assy needs to be replaced, them you have options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch micro-switch logic is messed up.
Hope helps.
Jan 03, 2011 | Dacor ECD230 Epicure Electric Double Oven
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Oven is locked cancel/secure bottom is not working turning the electrical box does not work.. what do we do
Try pressing in on the door while trying to release it. The friction of the latch may be keeping the latch from opening.
Nov 26, 2009 | Dacor ECS230 Epicure Electric Double Oven
Dacor Oven
Depending on your model it is usually at the top behind the "grill" of the oven that is not working. Take out the screws aournd the oven latch (usually for cleaning) and slide out the grill. The limit switch is either over the latch or to the side. If it popped, just put it back with a screw driver. If that is not the issue, then it it could be a bigger issue.
Aug 12, 2008 | Dacor ECD230 Epicure Electric Double Oven
Can not unlock Oven Latch
We can't even get the door back on after taking it off to install the damn oven. Now it will cost us $150 service call to get the door on. This oven is a nightmare.
Jul 19, 2008 | Ovens
Aug 31, 2007 | Dacor Millennia MOV130 Electric Single...
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor ECS127 Epicure Electric Single Oven Logo
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
