Vbsr2080 woww my washer isn't draining the water or spinning anymore at the end of the cycle. what could be wrong and how do i fix it?
  • Washing Mach... Master
  • 744 Answers
If the drum is spinning then it's the pump if not then it could be the motor or belt
Posted on Jul 22, 2013
mikedurland
  • 481 Answers
SOURCE: fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Posted on Jun 27, 2008
  • 1550 Answers
SOURCE: my washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Posted on Jan 31, 2009
  • 15 Answers
SOURCE: washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Posted on Jul 09, 2009
beltronic205
  • 1474 Answers
SOURCE: Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Posted on Apr 09, 2010
Macmarkus
  • 2605 Answers
SOURCE: my frigidaire affinity front loading washer does
Hello, welcome to FixYa
It sounds like the unit is detecting an unlocked door, loose wire, bad reed switch etc. hence the control will not initiate a hi-speed spin.
I know most folks will rule out the lock initially because the unit does indeed "lock", however, the lock on these machines are a two part device, a set of contacts to lock and a secondary contact to activate hi-speed spin, i.e.
If it does indeed drain fine, then here's the next place I'd direct you to investigate.
**Unplug the unit from the wall first...safety first**
It will require you to visually inspect the control board, thus needing to remove the top panel by way of taking out the screws at the back and sliding the panel back and up.
What to look for specifically is the wires with the green connector fastened to the board securely...I've seen a few vibrate loose thus preventing the unit from spinning, i.e.
If loose, push it all the way in until it cannot be pulled out with a slight tug ( there are clasp's on the connector but I suspect sometimes they aren't secure when leaving the factory...just my suspicion )
If these things can be ruled out, then it is quite likely the door switch (95% of the time), so here's how to change/access the latch assembly...There should be a tech sheet underneath the tub assembly behind the access panel for test procedure of the switch.
**The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace.
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Jun 01, 2011
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Maytag navigator washer not draining all the water out
Here are some things for you to check out
Please read fully this covers a couple of different brands but it is all the same things to check ok?
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jun 23, 2011 | Maytag Washing Machines
Spin cycle not working
When you say the spin cycle is not working do you mean that nothing works in the spin cycle. For example: Does the drum move or does it move and but the water isn't drained out?
Jun 19, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
My washing machine isn't getting rid of all the water during the last spin cycle. The clothes are still very wet when it is done. I run the spin cycle more and it only rids a little water from the...
Behind the washer is a plastic hose that enter the drain.Make sure that nothing is pinching it closed.You can also use drain cleaner in the drain but not in the machine.
May 12, 2011 | Washing Machines
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
