Question about Rohl Home
How to remove rohl shower valve trim - Rohl Home
3 Suggested Answers
  • 68 Answers
SOURCE: Water leak outside valve
You have a leak where the back plate goes up to the wall OR there is a gasket missing from the trim installation. If this is a tile shower i would suspect the first and use clear tub/tile chaulking to seal around the edge of the plate paying close attention to the grout lines.
Phil
Posted on Dec 09, 2008
  • 61 Answers
SOURCE: I just installed my Delta Multichoice Valve Trim
If you look inside the shower head from the back where the threads are you can see a flow restrictor, if you take it out you get a lot better flow.
Posted on Jul 01, 2010
Any idea how to open the grey part where the water comes out of this rohl 1151/8pn handheld shower?
Joe, Soak that head in a plastic bag or container of vinegar and it will remove most if not all the deposits, just give it a little scrub with old tooth brush a few times put back in vinegar for approximately 4 hours or leave overnight. This may also allow easier disassemble.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Top 3 Tips For Cleaning Your Shower Head
How to Clean the Showerhead with Vinegar
Tie Bag of Vinegar Around Your Shower Head to Clean It with No Effort
How to Clean Your Shower Head Easy Bathroom Cleaning Ideas Clean My Space
May 26, 2016 | Rohl Home
Any ideas how to open the grey part where the water comes out for Themis rohl 1151/8PN handheld shower?
It looks similar to one I've cleaned before You gently pry around the diameter of the smaller gray part to get it to pop off then remove screw holding disperser from head
My plumbing supply house was suppossed to order my Rohl shower set up with cross handles (RA4914 & 4912). Instead he ordered the lever handles. My sink faucet (RA1408) was ordered correctly with the...
Nice.
Paying that price for your shower faucet, I would think the supply house would work with you on that. eBay shows cross handles so they are available.
The plumbing supply store should be able to order what you want.
Sep 12, 2017 | Rohl Perrin & Rowe Exposed Tub or Shower...
I have a Perrin and Rowe Diverter valve U.5383 for a hand held shower that I need to disassemble to replace the spindle. Is the right hand side housing threaded? There is a hex nut on the housing (exposed...
Soak the unit in very hot water 50/50 with white vinegar for 2or 3 hours to loosen the lime in the threads and try it again. Keep the water hot no boiling but hot.
Feb 02, 2011 | Perrin and Rowe Rohl Bath U-5386 ; U 5386...
Replaced trim ring and handle, now hot is cold ,cold is hot
Remove the handle and turn the stem of the cartridge 180 degrees then put your handle back on.
Apr 27, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking shower head
Very few shower heads are made to be rebuilt and any O-ring will always be proprietory (i.e. specific to that brand and part). Rohl has an excellent customer service department. The can tell you if the parts are available and will also tell you to get them. 1-800-777-9762.
Apr 19, 2010 | Rohl Shower Shower Head 1025-8
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes...
    Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
    Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
    Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
    I hope some of these ideas help
    Mar 01, 2009 | Plumbing
    Phil
    Dec 09, 2008 | Rohl A2400 Country Bath TRIM ONLY PRESSURE...
    Home Logo
    67 people viewed this question
    Top Rohl Home Experts
    Donni Steen
    Tom Chichester
    Are you a Rohl Home Expert? Answer questions, earn points and help others
