Question about Pride Mobility Products Health & Beauty
Fault codes falt code --- ---- --- ----.it won't move . what does the code mean?
  • mbony853 Jul 23, 2013
    I finally got someone at the factory and was told theat the
bobiii84
  • 65 Answers
SOURCE: kia spectra fault code 1586. What does it mean?
http://www.troublecodes.net/Kia/
Sounds like you need to replace your ECM for your Transmission.
Posted on Jan 16, 2010
JackHeath
  • 1049 Answers
SOURCE: What does this falt code mean? 8002291A
Trophy Error 8002291AIt thinks that you are using a save file that no longer matches the trophy data. Essentially your save file or the trophy data is corrupted and no longer accessible. Usually, you just need to wait for the game to update.
If that doesn't work.
Easy fix, delete your saves...hard fix, try and fix the corrupted data.
Posted on Apr 27, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: It won't start and displays
Hello
This is a solid state thermostat error code,which is a control board issue.
Your going to need a new control board or a replacement air conditioner.
Sorry
Posted on Aug 01, 2011
ercupa190
  • 12223 Answers
SOURCE: ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jul 20, 2012
skychief2001
  • 21873 Answers
SOURCE: 89 firebird anti theft code won't let car start
If code 53 involves the PASS system for your car, the chip in the key has failed, or the sensor in the lock cylinder, or the control module.
The anti-theft system disables the starter and the fuel injectors. You could bypass those circuits to get the car started.
Posted on Oct 02, 2012
Man TGA 440 falt code 03300-06
I can't answer your question about Dolls, Playsets & Toy Figures "Man TGA 440 falt code 03300-06" because simply, I can't understand whay do you mean.
Please reformulate your question, so maybe someone else might help you
May 04, 2015 | Toys
Falt code p0819
needs computer reset
Mar 01, 2015 | 1999 Jeep Grand Cherokee
My jazzy 1170xl plus won't move. When I power it on the lights come on like there supposed to but as soon as I move the joystick the battery level lights start to flash rapidly. 9 of the 10 lights...
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Apr 29, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
Showing LL error code
This error code means LARGE LOAD and shows thatthe machine is overladed with washing. Remove some and reset the machine and all should be well. If the fault persists then the following will need to be checked:
Sep 08, 2012 | Washing Machines
Service stabilitrak and car won't move
A scanner needs to be used to diagnose concerns with these systems, keep in mind that codes are fault indicators that are set to turn the lights on. Note this code number and came back for additional details.
Hope this helps.
Feb 14, 2012 | 2006 Chevrolet TrailBlazer SS
2002 grand prix engine light flashing. What could that mean?
  • The check engine light means that the PCM has been sent a fault code from one of the many sensors. So the next step is to go to any major parts store and have the codes read for free. When you get the code you can find out what is wrong and how to go about fixing your car and make the light stay off again. Until you get the codes you won't know what is going on. You can post them here if you like and I will further assist you. It can be minor or major but you won't know until the code[s] are pulled.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 06, 2011 | 2002 Pontiac Grand Prix
It won't start and displays E3 fault code. Manual says this is faulty coils? Took apart and cleaned all, looks good. Still has code displayed and won't run. How to clear fault code? Thank You.Jeff
E3 means "unit-abnormal protection to avoid occurence of unit damage."
Manufactures does not recommend that a homeowner try to attempt a repair on a code like this as it indicates possible wiring or internal problems. Have you checked for an internal fuse on the circuit board? I would also check the incoming power to make sure you have the proper voltage. You can also try unplugging the unit, waiting 30 seconds and plug back in to see if the code disappears.
According to A/A brands, if this code appears, shut off device and call authorized service company. I'm just trying to get you some things you can check yourself prior to doing that.
Hope this helps.
Jul 29, 2011 | Home Pride AA-TH 358 Air Conditioner
Gwl11 washer
Code 248.there should be paper with fault codes inside the control box area if you undo it by 2 phillips head screws.
Jun 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
Health & Beauty Logo
27 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
