I have a panasonic dvd/vcr combo recorder model # es35v and I lost the remote to it. I need to get in the menu so I can take it off tv and put it on dvd so I can watch movie. I don't know what to do with out a remote can u heip me?
My dmr-es35v can't read any kind of dvd. what can be wrong?
Laser pickup unit fault. Check and replace it. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 18, 2017 | Panasonic DMR-ES35V Multisystem Code free...
U99 error code on dmr-es35v panasonic recorder what is this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to many popular devices are given.
Feb 12, 2015 | Panasonic DMR-ES35V Multisystem Code free...
Remote broke how can i record vcr/dvd player . wnat to record on my vcr?
I assume this combo unit has basic front panel buttons (behind the right-hand door - where the copy button is) - there should be a drive select (VHS or DVD) button stop play record. I strongly advise if you really need a remote for this model, particularly when it comes to menu/setup options, that you search various online and similar stores for one.
The cost will depend where you go and who you deal with - and if the remote is available (you can always ask Panasonic about a remote for a DMR-EZ48V even though your model may be a DMR-EZ47V - they both use the same remote (N20AYB000136 or equivalent number); they can probably tell you how to order one through them, the price, etc.
A universal remote may work, but with limited functions. If the combo unit works in general, you should not have too much trouble obtaining a replacement remote (just keep in mind the model above).
The remote may cost just over $100 but remember, this is only if you want full control of your combo unit.
Mar 13, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Remote doesn't work for DVD Recorder
It is now working. The DVD is below a Panasonic TV. We blocked the tv remote sensor and the DVD remote started working. We have unblocked the tv sensor and the dvd remote is still working. I'm not sure what was wrong or how exactly we fixed it.
Jan 28, 2009 | Televison & Video
Panasonic DMR-ES35V
I have a dmr-ez25eb DVD recorder and it has stopped Recording and playing back , the screen on the TV says that its a none recordable disc but I have been useing them from the time I purchased the DVD
Aug 31, 2008 | Panasonic DMR-ES10 DVD Recorder
I need the codes to ste the remote control; dish for a Panasonic TVCR Combination TV Ser
i need the code to program a panasonic tv/vcr combo using a dish remote control.
Aug 30, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
Televison & Video Logo
Top Televison & Video Experts
