Question about Asko W6021 Front Load Washer
MY ASKO WL6511 is leaking, what can I do? - Asko W6021 Front Load Washer
Hello, I have an Asko washer model 20005 leaking water from both heating units where they attach to the drum. Both have been replaced and "not overtightened" by repair person, but still leak...
Only one answer really- recall the 'repair person'. He or she should have carried out the repair properly and completely and ensured that there were no leaks from the units after replacement. That's what you pay for.
Maybe they used the original washers and not new ones, for instance? Are both heating units 'OEM', that is Original Equipment Manufacturer (Asko or whoever actually makes the washer) or less expensive 'copies'?
Put pressure on ;-0)
John C
Mar 05, 2011 | Asko Washing Machines
Asko d3350 has the f2 flasing and pump just runs
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
Mar 03, 2011 | Asko 24 in. D3350 Dishwasher
Hello, I have an ASKO Washer model W6461 and I notcied a puddle (1/2 cup) under the front right part of the machine after running it once. How do i get the service manual for this machine so i can...
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
Jun 15, 2010 | Asko W6461 Front Load Washer
Leaking dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
hafhgf
May 16, 2010 | Asko 1385 Dishwasher
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Asko Washer leak
Remove the bacpanel, and locate the leak. Be careful for moving parts, and electricity.
It may leak from the pump or from a hose or so.
Jan 15, 2008 | Asko W6441 Front Load Washer
Asko washer 20004
where does the leak appear at?
Sep 17, 2007 | Asko W6441 Front Load Washer
Asko W6021 Front Load Washer Logo
23 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
