Question about Vehicle Parts & Accessories
Will quit shift into neutral will start but when you come to a stop then engine won't stay running you let the van sit for 2.5 hrs it starts no problem until the next time can this be the coil I chan
    New Friend:
  • 53 Answers
What make and year van?
Posted on Jul 23, 2013
2000 Honda Valkyrie Interstate will not start
Hi, Brian the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
DOA Won start
Won start unless in Nuetral GL1500 Information Questions goldwingdocs com
Honda GL1500 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 12, 2018 | 2000 Honda Valkyrie Interstate
2007 Yamaha Road Star Silverado neutral light stays on
Hi, Yexer #2 or #5 and the usual suspects are:
1. Neutral light bulb burnt out.
2. Faulty neutral switch.
3. A loose bulb in the socket.
4. Faulty wiring from the neutral switch to the light.
5. If the neutral light stays on while the bike is in gear the wire from the light to the neutral switch is grounded.
The ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
The above checklist is most reliable if performed with a warmed-up engine.
Neutral switch issue
Forums The Roadstar Clinic
Yamaha XV1700PCRC Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Mar 15, 2018 | 2007 Yamaha Road Star Silverado
My2002 R1 won't start no green neutral light when I turn the key the yellow check engine light lights up
Hi, Kevin the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
neutral light wont come on when in neutral and wont start with kick stand.
No neutral light bike won start
Yamaha YZF R1P Service Manual
OEM parts for Yamaha
Yamaha YZF R1P Owner Manual
Sep 22, 2017 | 2002 Yamaha YZF-R1
Backed out of driveway, van would not come out of reverse. pushed to side of road. dash light stays on "R" and van will not start at all
Sounds like a possible shift linkage problem. Follow linkage back from your transmission, look for bent levers, broken or bound up pivoting connections. The neutral start switch prevents starting of engine when transmission is not in neutral or park.
Aug 02, 2015 | 2004 Toyota Sienna
2004 Dodge Sprinter abrupt engine shutdown.
need more info does it run warm
Jan 29, 2014 | Cars & Trucks
Intermittent failure to start,2004 Toyota sienna,move out of park to neutral,back to park,starts right up,neutral saftey switch????
Yes this would be a transmission neutral safety switch problem. the switch sit over the post that the shift cable attaches to on the ****** case. Picture below.
Oct 22, 2012 | Cars & Trucks
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
I am having periodic problems with my truck stalling when I go to shift down to first when coming to a stop. It just stalls out then won't start & floods. After letting it sit for 15 - 20 min it...
It is possible that it is coincidence. Check if after revving it would stall after when your truck is in neutral or in park. This is to isolate the problem if it is the engine when in load or the transmission.
Is this a manual transmission? If there are shifting issues it may be the clutch. Other than that have the fuel pressure tested. The fuel regulator may be faulty or there are leaks or bad lines on the vacuum hoses.
Sep 08, 2011 | 1999 Dodge Ram
1995 DODGE CARAVAN worked perfectly until recently
you need to replace the neutral starting switch on the transmission,it is a screw in type and has a connector with three wires on it,or start your van in neutral.
Jan 02, 2010 | 2001 Pontiac Aztek
Vehicle Parts & Accessories Logo
159 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
