Question about Compaq Presario SR1703WM PC Desktop
Not sure if set is complete
How many disk does it take to recover my pc. I have a set of 10. But when i get to the last one it only at about 50% and asks for an 11th disk that i dont have.
    Brigadier General:
  • Compaq Master
  • 3,400 Answers
Gilbert,what is your Os that might help.and have you run sfc /scannow when the computer asked discs.
Posted on Jul 21, 2013
Takes 5 minutes to start up
Try running disk clean up and then disk defrag. After that open a browser on the internet and click on tools and then internet options. Click on browsing history settings and make sure its set to no higher then 50. Reboot your pc and test how long it takes to start up after all of the above are complete. There are other things you can check and correct to speed up the pc but they are tougher to explain by posting a message and I dont want to start you on something that you may run into problems with completing it.
Oct 31, 2011 | HP Pavilion Elite e9220f (NY552AA) PC...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
I want to recover my computer to factory settings
As soon as you press the power button on your notebook, Keep tapping F8 repeatedly. Another screen should pop up with a list of commands (safe mode / start up repair etc) Near the bottom of the list you should see an option to ReInstall windows / Reset to factory Default. Select which one you prefer and follow the simple instructions.
Hope this helps and please rate thanks.
Mar 13, 2011 | Toshiba Satellite L305D-S5881 Notebook
My intel wireless adapter displays error code 10 and this device cannot start.
Suggest you reinstall the driver from your drivers cd that you got with your laptop. Alternatively get driver from the manufacturer's website.
If you still get this issue, then usually points to a hardware failure
Make sure that you have already tried switching the PC off and back on again.
As a last resort, you may want to recover your pc back to its factory setting with your recovery disks and if still not detected, almost certainly a hardware problem
Hope this helps
Nov 12, 2010 | Intel PRO/Wireless 3945ABG Network...
Acer Aspire SA80 desktop: Trying to recover PC to Factory Setting
The error your getting means leaking memory,, replace the rams and it will complete restore..
NTLDR is part of the booting system of the computer..basically the computer cant find the file..
Contine with the system recover after you change the rams,, you'll be fine..
Mar 12, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My Toshiba M55-S135 laptop has a PXE-E61 Error upon starting. I did make sure the Boot is set to HDD first and LAN LAST! Still have this issue. It won't even run the Toshiba recover cd. Please help me....
Is your BIOS actually recognising your hard disk drive.
It sounds to me very much like it isn't seeing your hard disk as a physical drive and therefore as the "last option" it is trying to load a PXE image from a network server via your LAN connection.
Can you not remove LAN from your boot options completely and see then if you get message similar to
"Operating System Not Found"
My advice would be first to see if you can boot from a CD if you can boot from a CD e.g. Windows Setup CD or Knoppix then my best advice would be to test with a new hard disk drive and try installing your operating system onto a new hard drive.
Kind Regards
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | HP Pavilion ze2000 Notebook
IBM Thinkpad r51 unable to recover/restore
In restoring your computer factory defaults it enables your computer to set its first default settings and eventually all your data stored in your computer will automatically erase. So then you purchase a recovery software and having some problem in installing it. Maybe because not all software will run in different platform or version of operating system. So my advice: Please find some computer shop in your area, a shop with complete equipments in order for you to recover all your data stored in your computer and let them recover it for you. In that way you are assured that they can do it fast and effective.
Thanks
Aug 04, 2009 | IBM ThinkPad R51 Notebook
Check disk problem
the hard drive is failing... recover everything you can from it before it quits completely
Robert
Jan 23, 2009 | E-Machines eMachines Desktop PC
I have misplaced the recovery CD for Sharp Actius RD3D PC Notebook and I need to re-install the Operating System, so I requires Drivers for its hardware components, Also if possible an another official...
You do not need the CD to recover this laptop.
From the User Manual:
1. Turn on your computer. When the message <F2> to enter System Configuration
Utility appears on the bottom left of the screen, press F2. Then, the Setup Utility
will open.
2. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
3. In the Exit menu, confirm Exit Saving Changes is highlighted and press Enter
twice.
4. The system will restart. When the message Press F10 to Recover appears on the
screen, press F10.
5. Read the message on the screen, and select the way to recover your system; then,
press Enter. If you selected Formats hard disk and creates new partition, go to
the next step. Otherwise, go to Step 10.
6. Select the volume of C: drive and press Enter.
7. Read the message and select Continue; then, press Enter. The formatting and reinstallation
will start.
Although the pointer may be shown on the screen, never touch the
keyboard or the mouse during recovery except when the message prompts
you to. If you touch them, the re-installation will be canceled.
8. When the re-installation process is completed, the system will restart
automatically.
9. Set up Windows XP by following the on-screen instructions. When you complete
the Windows setup, make sure to set date and time.
If you need help understanding these instructions, feel free to ask.
Jan 08, 2009 | Sharp Actius RD3D Notebook
Factory settings
I find that your notebook is shipped with Operating System disk and Application and Driver recovery disk.
The steps to reinstall the OS using the OS disk are available in the link provided below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00681978&dlc=en&lc=en&jumpid=reg_R1002_USEN
Instructions about reinstalling preinstalled Applications and Drivers are provided in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00400062&lc=en&cc=us&rule=23097&dlc=en&product=1144546
Reinstalling the OS using Recovery manager if your Notebook is shipped with one.
1. Click Start.
2. Select "All Programs".
3. Select the "System Recovery" option.
4. Select the "PC Recovery" option.
5. This will open a new window with the options "Microsoft system restore" and "PC Recovery".
6. Select the "PC Recovery" option and Click next.
7. Now you see the Windows XP LOGO with Please wait...... message
8. Welcome to PC Recovery screen will appear Click OK
9. Click Next.
10.Then you can see the option " The PC Recovery was sucessfully completed Click Restart to restart the PC or Click Turn off to turn off the Notebook"
11. Click Restart.
Steps to Recover the Notebook from a set of Recovery Disks:
1. As soon as you boot the Notebook with the recovery Disks we can see the following 3 options:
i) Click R for Standard PC Recovery options
ii) Press 'F' to format the Hard Drive and reinstall the original factory settings (All data will be lost)
iii) Press Q to quit this menu
2. Press F.
3. Press Y.
4. Welcome to PC Recovery window will appear Click OK
5. The recovery process will be started and the process will prompt to insert the next recovery disk. Please insert the next recovery disk when prompted.
6. Please insert the recovery disk whenever prompted for and click oK.
7. The message "The PC Recovery is complete sucessfull" will appear.
8. Click Restart to restart the Notebook or Click Turn off to turn off the Notebook.
This will complete the recover process using the set of recovery disks
Aug 09, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario SR1703WM  PC Desktop Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
