Ricoh Aficio Nashuatec CL 3100 printer C7417DN is showing error code sc320 what that ment
Soulvisitor
  • 1113 Answers
SOURCE: Ricoh Aficio 1018 photocopier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Posted on Nov 30, 2007
bowdo
  • 78 Answers
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
SOURCE: Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
Posted on Apr 30, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
  • 10 Answers
SOURCE: i have problem with Ricoh Aficio 1113, error code
I am assuming you really meant an Aficio 1013 - SC320 indicates a polygonal mirror motor failure. This motor drives the mirror that distributes the laser to the drum. Could be a defective motor, poor connection between the motor and the BICU - one of the motherboards, damaged cable or defective BICU.
This will require a service call. Probably looking at an hour to diagnose the exact problem and an hour or two to repair plus parts. Could be as simple as a loose connector --- doubtful, but you never know.
Posted on Dec 26, 2009
Error code sc320 showing on infotec 4151mf
That is a polygon motor error.
This motor is from the Laser Unit. Probably you have to change it.
If you do not have technical training i advise you to call your provider.
Mar 11, 2011 | Ricoh Aficio 250 Copier
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
I have problem with Ricoh Aficio 1113, error code sc320
Dec 24, 2009 | Ricoh Aficio 150 Copier
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Apr 30, 2009 | Office Equipment & Supplies
Apr 10, 2009 | Ricoh Aficio 1013F Copier
61 people viewed this question
k24674
jasbo
jasbo
