Question about Welding Tools
Miller econotig repair
Miller econotig. output is weak. both for tig & stick. not enough juice to weld. allready cleaned contacts. didn't help. any ideas?
  • 3 Answers
SOURCE: bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Posted on Dec 28, 2008
CarlGehrke
  • 169 Answers
SOURCE: miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Posted on Jan 26, 2009
  • 87 Answers
SOURCE: Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Posted on Oct 20, 2009
Testimonial: "appreciate the help."
co7196
  • 3433 Answers
SOURCE: Miller Syncrowave 200 wont strike arc for TIG
proper polarity?
Posted on Nov 12, 2009
  • 5603 Answers
SOURCE: miller 250 dx tig willnot
The inverter or control of it has failed. Unit will require servicing. If you are not electronically adept, this is NOT DIY. Do your best to check the control pedal wiring, especially connectors and the cord near connectors.
Posted on Jun 25, 2011
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
    Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
    Nov 21, 2013 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    The power light comes on our econotig but not welding, all connections are secure and grounded, whats the problem?
    checking incoming power supply voltage,if its right check output voltage(DC voltage showing in the manual)if not working,,,machine has to be checked thoroughly
    Apr 17, 2012 | Miller Welding Tools
    I have a miller econotig and the amp rheostat seems not to respond when turned to a lower setting
    Wendell,
    Call the Miller Help Desk at 920-735-4505 and ask for parts. Give them your machine s/n and they will get you the replacement rheostat. Good luck.
    Jan 31, 2012 | Miller Welding Tools
    Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
    It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
    Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    I have a miller sycrowave 250DX i have been tig welding for about 10 years i bought this machine 2nd hand hoping it would work ok when i weld in AC and hq the arc seems like it just wants to stop it...
    Did the machine ever work properly? I am assuming you are using a remote for tig welding. If you watch the points, does the HF stay on after the 5 to 10 seconds as you stated. It should stay on as long as you activate the machine. Make sure your Start Mode is in continuous. See page 42. Since there are so many options, check page 34 for help setting the options. If you still cannot get ti to weld properly, contact Miller for service. https://www.millerwelds.com/files/owners-manuals/O363AU_MIL.pdf
    Aug 29, 2017 | Miller Electric Manufacturing Electric...
    Poor weld quality- porosity. non directional arc, dcen.
    Tig need to very clean prior to weld.Stainless steel wire brush.or dics sand new disc. Argon Gas.
    Tungsten needs to be ground the write way. seen Miller.com they have free info for you.How to Tig.
    Feb 19, 2011 | Welding Tools
    Welding Tools Logo
    239 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
