Question about Garden
I have a Ford riding mower. When I try to start it I get a high screeching noise an the flywheel won't turn
    New Friend:
  • 3 Answers
Try w/d on top of your starter throw gear, just a tiny bit on the outermost shaft, check cable connections for corrosion, inspect starter engage gear for ware,
Posted on Jul 22, 2013
I have a 99 Ford Superduty 7.3 Diesel. It is making a really bad grinding/screeching sound just after it starts and is warming up. It wouldn't ******* off all the way even after the key was turned
indicates that the starter motor is stuck in the ring gear
possibly faulty starter relay or starter solenoid
pull the starter as the pinion over ride clutch is probably damaged ( noise ) and have the start circuit and relay checked
have the starter bench tested for serviceability by an accredited auto electrician
May 03, 2017 | Cars & Trucks
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
2006 Chrysler sebring High Pitch Noise Screeching Sound
The belt is slipping or the compressor and/or clutch is bad.
If the compressor won't turn freely with the engine off, it may be locked up which will make the belt screech.
Jun 27, 2012 | 2006 Chrysler Sebring 2.7
Wizard riding mower won't start.
with jumper cables jump from the battery direct to the starter if ok sounds like the safety switch on the brake pedal is bad
Apr 27, 2012 | Garden
Briggs and Stratton riding mower 18 hp backfire and won't start
Pull the flywheel and check the keyway. It may be slightly sheared.
Oct 09, 2011 | Briggs & Stratton Garden
I have a old Snapper riding mower with an 8hp Briggs and Stratton engine, The other day it wouldn't crank so I changed the switch and the solenoid, the battery was fully charged and it still won't...
make sure thers power going into the starter
if there is then see if the starter is siezed, try turning the fly gear, but not just up against the flywheel but try turning the starter backwards to see if it moves
Jul 29, 2011 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
