Reset sharp projector
How to reset lamp 1 and lamp 2 on a Sharp XG 50 projector
mastertech48
  • 149 Answers
SOURCE: sharp xg-e850u projector owners manual
I've searched all over...heh, I've got TONS of Sharp service manuals but *not* yours...I did find, however, the xg-e650 manuals on manualsparadise.com. Sharp units, a lot of times, are very similar in architecture, functions, parts, etc. For example, practically any Sharp remote will work on your projector...BTW, the lamp you need is a BQC-XGE850U/1 and sells for $292-389 dollars.http://reviews.cnet.com/peripheral-accessories/sharp-projector-lamp/4505-8309_7-31382143.html?tag=mncol;lst
Posted on Sep 09, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XG NV51XE lamp reset
if you get no led on the top, reset the bimetal breaker. take off the top and press the red button on the front of the lamp housing.
Posted on Dec 23, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp xg-nv3xe lamptimer reset
hod down enter, menu, and down arrow, then press power.
  • 3278 Answers
SOURCE: sharp xg-ph50x dlp projector shows vertical bars,
Hello.
That is an indication that lamp 2 is failing.
Hope this helps.
Posted on Mar 30, 2010
arthurroger
  • 170 Answers
SOURCE: auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Posted on Apr 23, 2010
I have a Sharp Projector model XG-E3000U that won't power on. Nothing happens at all when you turn it on. No lights, no fan, nothing. I opened it up and checked the fuse and that's good. Is there a reset...
the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 18, 2010 | Sharp (CLMPF0046DE01) Projector Lamp for...
Installation projector sharp xg-e690u
Unplu the unit
Locate the user service screw, the lamp door should be underneath the projector.
open the lamp door
the lamp is removed by undoing 2 or 3 screws and pulling out with the handle.
a genuine replacement lamp with cage will mean you won't have to worry about wiring the lamp.
put new one in push connectors in firmly
do up the 2 or 3 lamp screws close the lamp door and screw up
reset procedure usually plug in power while holding down up, left and power and the lamp will be reset.
Hope this helps you
Good luck
Hope this helps
Nov 30, 2009 | Sharp (BQCXGE690UB1) Projector Lamp for...
Sharp XG-C50X Notevision. Doesn't get past "warming up"
it seems that the powersupply is failed
Have a nice day!
Jerry
Lampdeng Limited
Nov 21, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp xg-e850u projector owners manual
Sep 08, 2009 | Sharp XG-E3500 Multimedia Projector
Sharp XG-E650UB LCD Projector
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Aug 07, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Need to reset lamp counters on a sharp XG-V10WU
1 turn projector switch off
2 remove lid and remove lamps
3 replace lid with out lamps
4 turn main switch to the on position
5 press the on switch on top
6 press enter
7 flip main switch to the off positon
8 replace lamps and lid
your done!!!!
Aug 03, 2009 | Sharp Projector Lamp for XGV10WU
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
Sharp LCD Projector
bqc-xvh37u/1 you can get it through www.projectordoctor.com. but they only have one left.
Jul 04, 2008 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
SHARP XG-E1000UB
the model # you have given is for the bulb, not the projector......
Sep 12, 2007 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
50 people viewed this question
jasbo
jasbo
