Frigidaire lra157mt1 water sitting in unit, where does water come out of unit
Frigidaire window air conditioner LRA157MT1 worked yesterday. Today fan works but it doesn't cool?
unplug it if you can and let it set for 20 minutes, set the temp control where you want it and plug it in, wait a bit and see if it starts cooling. you can confuse these things if you turn it off and on rapidly or change the temp control up and down sporadically. The compressor has to take it's time to kick on after it has been shut off and then on again.
Jun 11, 2017 | Frigidaire Heating & Cooling
Dirty water backs up into unit
The drain valve needs to be checked , also try cleaning the drain hose , it could be clogged , leading to improper drainage .
Lemme know if this helps
Mandeep
Apr 20, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Unit will not turn on, what do I do now?
there is a reset on the plug sometimes if there is press it
May 19, 2013 | Frigidaire New Original LRA157MT1 Remote...
Fridgadare lra157mt1 reset button keeps poping out
It is tripping the outlet breaker. Change outlets or you will have to back down on the power with a different unit.
Sep 03, 2012 | Frigidaire FAC126P1 wall/window Air...
Some of the new style Air conditioners have a auto time delay built into them for power failures. If power fails or you unplug the unit, they will not come back on for about 3 to 5 minutes. This is a safety feature to keep power failures from damaging the compressor. Keep it plugged in for 5 minutes and try again. If still no go then call for service. You should have a 1 year warranty on it.
May 27, 2012 | Frigidaire Heating & Cooling
The water drainage hole on my fridigaire ac is only 2 inches from the front of the unit, thereby sitting on the sill itself and pouring water onto my sill and down the inside of the wall. Is this a...
Sounds like a defect to me or a hole has rusted through the condensation pan.Generally, all drain holes are at the rear of the pan. That's why the rear of the unit is supposed to tiled down 1/4" to 1/2". That way, the water flows to the rear of the pan.
I hope this helped you and thanks for choosing FixYa.
Jul 22, 2011 | Frigidaire FAA060P7A Air Conditioner
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
