Question about R&D Pro Flow Power Plenum For Yamaha Gp 1200 ()
Cilinder in the middle
Middle plug is wet wit water .. Just paid for rebuild on carbs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • R&D Master
  • 1,190 Answers
Did you start engine on trailer without water turned on from a hose pipe and then turn water on once running ? try again on the trailer for 2 min without water with all sparks and cylinders running , if clean running then add water and if it falters you got a leak on the head or exhaust system ! P....
Posted on Dec 11, 2013
2000 Bravada. Where can I get engine repair diagrams?
If you can't find a shop manual for a Bravada, check one for a Blazer. Basically same engine.
Jun 27, 2015 | Oldsmobile Cars & Trucks
I had a 1990 suzuki gsxr11oo with 7000 canadian km on it only im doing this again i was still the original owner this year i had to get rid of it.the bike was ok when i took it to the machanic for the...
If the bike has been laid up for a while without the carb's being drained, they lacquer up and need sonic cleaning to get them 100 per cent. The ringing sound from sounds like broken piston rings, the low compression reading on 4 confirm this, Sorry, it looks like major surgery required.
Oct 25, 2013 | Motorcycles
I had a 1990 suzuki gsxr 1100 motorcycle i was still the original owner i took it to a machamic for the first time to rebuild the carbs and he didnt do a good job at all when i went to pick it up i...
be very careful with the sounds that you describe, Sounds to me from the condition you describe without looking at it directly, May be that since the carbs leaking gas, over rich condition on cylinder 4, or a very bad job at setting the floats, Or a combination of both adjustment together
Oct 24, 2013 | 1984 Honda CB 700 SC Nighthawk
Spark plugs wet fuel
which motor are you talking about? 1100 or 1200? either way it sounds like you may have done something to the needle valve rocker arm and spring causing it to stick open and let fuel run straight into the engine running or not.
May 12, 2013 | Yamaha Water Sport
My poulan chainsaw,the cilinder gets oil,so the sparkplug gets wet and it will not start
Probably have a Carb. problem. Take the carb apart and clean. The Needle Valve sounds like it is sticking.
Jan 18, 2013 | Poulan Garden
Runs but quits
Probably gummed up carb. If you don't want to try to rebuild the carb, then try adding a really good carb / fuel injector cleaner to the gas/oil mixture. don't forget to use a very small amount, then run the motor as fast as it will go for short periods of time to try and dissolve the gumming in the jets.
Aug 28, 2012 | McCulloch Garden
Which ring on the carb needle do i put the surclip on for carb adjustment on my ktm sx 125. 1999
Thank you for contacting FixYa with your inquiry. I have been going
over some of the older help requests that have been archieved and
trying to provide solutions for those that didn't get answered. Hope
this information helps.
Start in the middle. Check you spark plug it should be a nice cocoa brown color. If its stumbling and not running correctly then lower it 1 notch (This Raises the Needle alowing more fuel) if the plug is fouled and wet then your over fueling in the middle to high end so raise the circlip (Lowering the needle - reducing fuel) adjust accordingly using your spark plug color as the guage.
The Main Jet determines fuel mix at top speed and the needle fits into it's oriface regulating speed depending on throttle position. You may have to to up or down a size depending on you altitude.
TF
Sep 05, 2011 | KTM SX 125 Motorcycles
I have a husqvarna model 136 chainsaw that wont start.Has spark,gas compression
trie with another spark plug if not heling check maybe air leak between cilinder and carb. also if not helpin rebuild carburattor.
Dec 03, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
91 olds cutlass 2.3 having problem with gas mixing with the oil......... the 2 outside plugs are dry and the 2 middle plugs are wet with gas
The wet plugs are not firing. The engine must be running rough. Check for spark on the middle two. Find the problem and change oil and filter.
Dec 04, 2009 | 1991 Oldsmobile Cutlass Supreme
R&D Pro Flow Power Plenum For Yamaha Gp 1200 () Logo
Top R&D Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a R&D Boating Expert? Answer questions, earn points and help others
