Question about Radio Communications
Bc145xl How do I program my scanner
4 Suggested Answers
johnny5846
  • 379 Answers
SOURCE: lost book to scanner its
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
Posted on Jan 13, 2009
WonderTech
  • 268 Answers
SOURCE: Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Posted on Sep 07, 2009
BillB-SA
  • 2761 Answers
SOURCE: how do I program my bc145xl scanner
I searched but could not find a manual for the BC145XL. Your keyboard looks identical to the UBC144XL though, so the instructions for it should work on your scanner. You can download the manual for the 144 here:
http://www.scribd.com/doc/2056189/UBC144XLT
Bill B
Posted on Feb 21, 2010
BC145xl. Where can I get frequencies?
Here's how to program;
How do you program Uniden Bearcat bc145xl
Go to this site and you'll see a U.S.map. Click on your state, then after click on your county and a list of freq's will be there for you.
https://www.radioreference.com/apps/db
Aug 31, 2015 | Uniden Radio Communications
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
How do I program my bc145xl scanner
Bill B
Feb 19, 2010 | Uniden BC244CLT Base Scanner
Cant get programed
Programming the BC350 is fairly straight forward, and the operating manual has very good step-by-step instructions. You can download and print the manual by following the link below. The programming instructions are detailed on pages 24 through 28.
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
Dec 31, 2009 | Uniden BC350C Base Scanner
I have a bc145xl and i dont know how to put in my frequency channels i got
I couldn't locate a manual for you, but the 16-channel BC145XL is a fairly typical Uniden scanner.
Turn the scanner power ON.
Press the MANUAL button to stop scanning.
Press the MANUAL button repeatedly to advance to the channel that you wish to program.
Enter the frequency that you wish to program, including the decimal point. Frequency range of your scanner is 29-54, 136-174, and 406-512MHz.
Press E (Enter) to cpmlete the process.
To continue programming, press MANUAL to advance to the next channel, and start the steps again.
Dec 09, 2009 | Uniden BC350C Base Scanner
Bearcat Scanner BC145xl
1. do you have a button marked "prgm"
if not, then push the manul button until it
then enter the freq ie... 155.475 and hit
enter, be sure to put the decimal point in.
UPSO506
Dec 29, 2007 | Radio Communications
Uniden # bc145xl scanner
How do I program my Uniden Bearcat BC 145xl? I lost the booklet.....
Oct 29, 2007 | Radio Communications
Help please
how do i program it
Oct 23, 2007 | Uniden BC244CLT Base Scanner
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
