Question about Garden
Replace the hose on a cleanforce 1800psi
Can't take old one off
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
How do I reset the mixture screw on my Honda GC series 1800psi 4.0 HP premium residential pressure washer?
use a starting setting of all the way in then back out 1 1/2 to 2 turns adjust for best run after that
Jul 15, 2015 | Honda Garden
What is the rubber hose that comes out of the t at the top of the loop of my dishwashers drain hose and what doese it connect to. The old drain hose I am replacing did not have that.
This hose?http://www.amazon.com/gp/product/B00379N7U6/ref=oh_details_o00_s00_i01
If so, the black hose is some part of the upgraded siphon. You can not order the old type hose anymore that I know of. So the only solution I know of is to replace your guide assembly which will have a tube on the top for that hose to plug into. There may be a way to 'rig' it to work without the updated guide assembly, but personally I am not taking any chances.
guide assembly:http://www.amazon.com/gp/product/B001DPFN4Y/ref=oh_details_o00_s00_i00
Feb 18, 2012 | LG LDF6920ST Stainless Steel 24 in....
How do I change the hose on a dc25 animal
To fit a replacement hose to your DC25, please follow these steps:
  • Remove the clear bin and cyclone assembly from your machine
  • Disengage the wand from your machine, and detach this from the old hose
  • To remove the old hose from the machine, locate the locking tab - push this inwards as you pull the hose up and away from the machine
  • Slot the new hose into place - the lower cord hook should face outwards, while the locking tab faces inwards. It should lock into place with an audible 'click'
  • With the new hose secured in place, you can now replace the wand and cyclone assembly
You may find the video embedded below helps in identifying the locking tab and fitting the new hose.
Alternatively, if you'd prefer one of our advisors to talk you through the process, please give us a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 03, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Heater core
Take the old one with...you mean rubber, not plastic, right? The heater coolant hoses?
The rubber hoses are easily replaced. You just need the proper size and length. Take the old one with you to any parts store. Add a little 50-50 solution of anti-freeze to top off your coolant after you're done.
If you mean some plastic hose, you'll have to explain.
Dec 01, 2011 | 2001 Nissan Xterra
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Looking for manual fh160d pressure washer Mculloch
Have you tried their website for the manual. Most products have websites with the manuals their for those that loose them or whatever reason they need another one. they are almost always free to download and print too.
Jul 13, 2010 | McCulloch Electric Pressure Washer 1800psi...
Need owners manual
hi, have a look on this site...it has just about every owners manual
http://manuals.syntigroep.nl/manuals.htm
Jul 23, 2009 | Garden
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
