Question about Cuisinart DGB-550 Coffee Maker, Grind & Brew 12-Cup Automatic
I own a Cuisinart DGB series 550 Grind & Brew coffee maker. It keeps shutting off midway through the cycle after the coffee has ground but all the water has not been released. I have replaced the filter with a new one and cleaned the machine. It continues to shut off prior to completion.
Noggin
  • 944 Answers
SOURCE: cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Posted on Mar 15, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: I need operating instructions cuisinart automatic grind and brew
Here si the link to the user manual:
http://www.cuisinart.com/share/man/966_man.pdf
-Tha Mp3 Doctor
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
Posted on Aug 02, 2009
dougpopo
SOURCE: cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Posted on Aug 03, 2009
SOURCE: Cuisinart DGB900BCC coffee machine. Problem is
I've solved my problem. Called Cuisinart customer service and spoke with a rep. The filter basket must be aligned. Shouldn't push down when putting basket into position. Also, cleaning underneath the bean grinder with pipe cleaner helped.
Posted on Dec 30, 2009
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
My cuisinart dgb-550 series the grind and brew one light is blinking on the of/on switch the grinder is not work and it is making hot water
While Cuisinart makes great home appliances, unfortunately they do not sell parts to anyone (no repair shops, not to individual customers) in order to fix what problems may occur with their products. The only way one can get a Cuisinart machine repaired is if they send the machine direct to the manufacturer where they have their own in house repair center.
Oct 27, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
My cuisinart grind and brew model dgb-700bc shuts off right before it is done brewing and i am getting coffee grounds in my coffee pot
Too much grounds or not running through fast enough. Right filters? basket flow hole vlesr? Sounds like it's backing up and flooding causing the grounds to get by yje filter. If you dare, **** the hole out just a tad. with the end of a sharp knife. not too much. You can always take out mor. This is called consuner calibration. Good Luck -Ned-
Sep 19, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
NEED oWNERS mANUAL FOR gRIND & bREW SO i CAN SET IT
if you go to this address you can download a manual...
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DGB-300BK-_E
if the address doesn't go just go to safemanuals.com and in drop boxes choose cuisinart/dgb-300bk. will take you to thie page.
enjoy your coffee.
Dec 02, 2008 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-550 Coffee Maker, Grind & Brew 12-Cup Automatic Logo
78 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
