Question about Sharp CD-C3800 Shelf System
Sharp cd-c3800 cd player jammed
When I am trying, it just says "cd disc 1", but tray is not coming out
  • kvasusa Sep 14, 2007
    not even got single reply for this.
  • kvasusa Sep 21, 2007
    When I was trying to play my own made CD, this problem started. When I try to eject CD. It says " CD Disc 1". Powered off and tried immediately, not working. Any otherway?
  • 790 Answers
You have defective mechanical CD Chamber, and mechanical Switch, or sensors under the CD chamber.
Posted on Sep 14, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Sep 14, 2007
    cleaned all timing switch and or sensors. and check the belt drive maybe they loose belt!>
Where can I get an antenna for Sharp CO-C3800 stereo?
It depends on the plug of the antenna on the system, if it is a female RF plug, you can use a normal bunny ears antenna with a female to female adapter.
Oct 26, 2013 | Sharp CD-C3800 Shelf System
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Dec 08, 2012 | managemylife.com
Inserted cd disc. play music on cd but will not eject the disc cd is stuck in cd player
Mostly The cd is jammed between the laser sensor and the cd rotator.Try removing the audio player and reseting the whole device if possible.Or if you have sufficient technical know how.Open the player try to manually open the disc tray.and remove thedisc.This can happen even  if the disc is broken inside the player.
Sep 28, 2009 | 2004 Jeep Grand Cherokee
Disc tray will not open for Sharp Blu Ray disc player
Unplug it, plug it back in, push the eject button FIRST it will automattically turn its self on. If that doesn't work its jammed.
Sep 08, 2009 | Sharp AQUOS Blu-ray Disc Player
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
CD Carousel for the Onkyo Shelf System
Oct 11, 2007 | Audio Players & Recorders
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Sharp CD-C3800 Shelf System Logo
319 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
