Question about Garden
Craftsman LT1000 Throttle schematic
I have replaced the carburetor on my LT 1000 B&S 42E707-2275-E1 motor, but the throttle now doesn't seem to effect the motor RPMs..Is there a diagram/schematic that shows how the linkages should be?
5 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
Posted on May 25, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
  • 16 Answers
SOURCE: I had to repair pull cord, in doing so I took the
go to sears.com and look up the actual engine number. they have a section for lawn and garden and in there there is a link to their parts lookup and they are very detailed. but you will need a pulse tach to set the govenor back to where it was and if it spun the govenor open too far due to the govenor not being hooked up, it could have came apart inside the motor and you will need to take it to a shop. as far as setting the govenor once you get it all back together, you need to push the throtle wide open and turn the govenor shaft in the same direction then tighten it down. yeah its not hard if you have done it before but if you havent and cant understand what i just said, save your time, and engine and have a shop fix it. and i havent seen a motor in my 9+ years that you had to remove all of that to fix a recoil rope.
Posted on Feb 04, 2010
BAMOUT
  • 2478 Answers
SOURCE: oweners manual for craftsman riding Lawnmower lt1000
Try www.managemylife.com
Posted on Oct 09, 2012
Snapper string trimmer throttle starts but will not idle down runs like throttle is open can not get engine to idle or run at low rpms
Perhaps something is stuck in the throttle actuator, or perhaps the carburetor is loose. Check the bolts or screws that hold it on the motor block, but if they are very loose, you probably should replace the gasket(s)!
Apr 19, 2017 | Snapper Garden
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
2001 Taurus RPMs drop every 10 seconds in park after warm
Could be IAC sensor maybe TPS sensor[RPM].
Jun 14, 2013 | 2001 Ford Taurus
Carburetor tune up
cylinder is letting something up to plug. sounds like a one in a million factory flaw.
Jun 12, 2013 | Motorcycles
Idles at 1000 - 1200 rpms won't drop
high idle could be caused by air inlet duct collapsed loose or air filter element clogged,idle air control valve failed,idle air inlet passage or throttle bore is dirty full of deposit,mass air flow is dirty out of calibration,throttle plate throttle shaft or linkage is damaged or leaking.have vechicle code scan first before buying new parts.
Oct 23, 2012 | 1998 Oldsmobile Aurora
My car, an xjs 4lt, 1996 cele', it has a aj16 engine, the idle speed is too fast & will not reduce, i've checked the butterfly & that seems ok, i don't know whether or not the step...
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor. Also the throttle plate could be binding in its bore and kinked accelerator cable, coolant temperature sensor might not be operating properly misleading the computer that the engine is still cold and computer throwing fuel at it raising the idle speed.----------
Getting this possibilities checked will help.Thanks.Helpmech.
Aug 31, 2011 | Jaguar XJS Cars & Trucks
Generator starts than shuts down on under voltage
The problem is related to the engine. When a load is put on the generator, the engine's throttle will want to open to maintain RPMs. If your carburetor is misadjusted or gummed/varnished, when the throttle opens, you will get a fuel starvation and the engine will die. If the generator is used regularly and hasn't sat for a while, first check to make sure the spark plug is good since you don't want to make a carb. adjustment using a worn plug. After you adjust the carb. manuallly flick the throttle to ensure that the engine doesn't 'stutter' or die out. If it does, increase the gas in the air/gas mixture and if that doesn't solve it, remove, disassemble and clean the carburetor.
Jun 30, 2011 | Generac Electrical Supplies
I think my '11 Monster 696 has a low idle. After warming up the engine and closing the choke the engine idles between 800-1000 rpms. As far as I know, the norm is between 1200-1300 rpms. Is there a...
If it doesn't stall out on you while driving, I wouldn't worry too much about it, I am not sure about the idle adj, I have never even bothered to look at mine, I know my 99 with carbs has an idle adj, and I know my 02 s4 stalls every now and then at a light, but never been a problem other than embarrassing. The choke is not really a choke but a low speed jet or idle jet because other wise there would be no gas going in the throttle, the twist grip does nothing till the engine starts. My 99, I can't touch the throttle till it fires or it will flood, (carbs), the 02, spin the throttle all day, it will never start. hit the idle jet, varoom, My 02 idles at 1100. Hope this helps.
Jun 28, 2011 | 2011 Ducati Monster 696
Craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Jun 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
