Question about Clifford 507X Security alarm + Remote start (93207054945)
Lost key to alarm
I have a 1992 Chrysler caravan 3.3 l. The alarm is a red flashing light that requires a small round key to go into a hole to turn the red light off so I can start the engine.
  • 3,799 Answers
You will need to contact Clifford and provide the alarm unit serial number and some other details, they should then be able to send you a new key. Failing that, call a car recovery service (AAA, RAC ADAC or AA) they can usually help.
Posted on Jul 23, 2013
Lost key and alarm dodge caravan
to reprogram new key first you need to use 2 factory program keys.place first factory key in the ignition first turn ignition on for 3 seconds. then turn off ignition then install second factory in the ignition on position for 10 seconds.when immobilizer warning lamp begins to flash a acoustic signal is emitted.within 60 seconds. switch ignition off and remove key.then insert new key and switch on for 10 seconds a acoustic signal is emitted and immobilizer warning lamp remain illuminated for 3 seconds indicating programming completed.if all fails dealership has to reprogram new keys.
Dec 17, 2012 | 2000 Dodge Caravan
My car has the round red light showing in the panel box. It will not start. The manuel says something about trunk circuit.
I have experienced this before, In my case the the RF (Radio Frequency) chip in the key had failed and when this happens the car is essentially locking its self from staying running; its a security feature. In my case the vehicle would start and then in roughly 2-5 seconds would shut off and the alarm light would flash (far as i know the round red light on the dash) You need a new key (NOT the key-less remote ) and then the key must be reprogrammed at a capable establishment such as a dealership or locksmith. To test if this is your issue try using the spare key, if you have one. If it starts and remains running using the spare then you know your main key is bad. Once again this may or may not be your problem, in my experience it was the key. On a side note its not very cheap to replace a key, and there are 2 different variations of the keys for your vehicle (04 Chrysler Sebring Based on your info we pretty much have the same vehicle; I have the 2.4l) The dealership referred to them as the grey and black version. Hope this Helps.
Sep 13, 2012 | 2004 Chrysler Sebring
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
I can not reset the alarm module because of that the car wont start so im just lost in this whole car.
Im not sure if this is a factory alarm or aftermarket, try locking and unlocking the pass/side door and see if car starts. if its aftermarket look under the dash for a red button, this is a default button,turn the key on and push this button in four times fast. then try to start the car. hope this helps.
Sep 05, 2010 | 1992 Chrysler New Yorker
Is there an easy online guide to changing out the ignition tumbler in a 1992 dodge caravan?
First remove the plastic 2 piece shroud around steering column so as to gain access to the housing the tumbler sits in. Find three Phillips screws to remove in holes in the lower piece.
Turn the ignition key to the Run position. Insert a small tip screwdriver in the access hole on the bottom of the housing to push the spring-loaded tab which will free the tumbler so you can simply pull the tumbler out with the key.
Installation is the reverse. Be sure tumbler with key inserted is set to the Run position.
Depress spring-loaded tab, insert tumbler into housing hole with tab down. All the way in,
Turn key to the Lock or turn it off.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 10, 2010 | 1992 Dodge Caravan
TDS 3-button keyless remote operating instructions please
RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
Apr 30, 2010 | 1998 Toyota Camry
Alarm red light stays on after you shut the car off 1998chrysler
I would turn the key on without starting the car then press and hold the black button till the alarm light flashes.Then turn key off take out of car and try the fob again.
Mar 29, 2009 | 1998 Chrysler Cirrus
Alarm has reactivated after being defunct for 4 years
The best way to solve this issue is simply sellling your vehicle!
Feb 09, 2009 | Hyundai Motor 1998 Accent
Ford fiesta transponder problem
I have a 2002 fiesta and recently it has been stopping on eac failure and then the imobiliser light keeps flashing and the car wont start not even turn over ha any one got a solution for this?
Thanks llinos
Nov 01, 2008 | Code-Alarm Code Alarm Transponder
Clifford 507X Security alarm + Remote start (93207054945) Logo
116 people viewed this question
Top Clifford Computers & Internet Experts
David Payne
David Payne
Are you a Clifford Computer and Internet Expert? Answer questions, earn points and help others
