Question about GE Refrigerators
Clogged defrost drain tube
I have a GE model GTH18EBT2RWW fridge. The power went out two weeks ago and I wasn't home causing a lot of meat juices to drain into the drain tube from the freezer. Now, it has left a nasty smell whenever the condenser fan runs. I already cleaned out the drain pan but the drain tube is still "tainted." I want to remove the drain tube out to give it a proper cleaning but there doesn't seem to be any accessible panels. Do I just yank it out with sheer force? Help, I don't want my house to smell like rotten meat.
  • 8 Answers
SOURCE: kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Posted on Nov 08, 2007
freetek
  • 5568 Answers
SOURCE: GE built in Fridge does not defrost and freezer ices up
Defrosters are commonly controlled by a primitive timer and this may have a 'dry' and a 'wet' (humid) climate setting that will cause the defroster to cycle generally every 12 or 24 hours.
If set wrong (by accident or on purpose), it can allow too much frost to accumulate before attempting to defrost.
This can cause a gradual buildup of ice.
Also the heating element for the freezer may have failed open so it never heats at all. The connections that need to be checked are often buried between the in- and outside walls.
The timer is probably still OK since you apparently aren't having a problem on the refrigerator side.
Posted on Jun 10, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
carlsbiz
  • 1124 Answers
SOURCE: Bad smell in new Kenmore Elite fridge
Remove the cover grill plate at the bottom front.Just give it a good tug to pull it off.. It is held on by tension clips.. There is were you will find the drain pan..
Not sure if that is where the bad smell is coming from but certainly a good place to check..
If that is not it - put few boxes of Arm & Hammer baking soda in the fridge and freezer..
Give it about 24 to 48 hours..
If that does not work - you may consider contacting the store where you got the fridge for a replacement.. Maybe - just - maybe before it got to your home - a small rodent might have clibmed into it and died..
A new fridge should not have these oderes..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Posted on Aug 05, 2009
aasc
  • 1606 Answers
SOURCE: GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Posted on Aug 19, 2009
I have a ge profile model pfsf6pkxcbb fridge. water gathers under meat tray and freezes. what is cause??
The defrost drain tube on the fresh food evaporator is froze up. every time the it goes in to defrost it leaks down the back wall. the best way to fix is to turn off unit for 24 hrs. they pull unit out remove back lower panel there will be two white tubes near the condenser remove and clean them. re install tubes and cover .
Jun 07, 2017 | GE Refrigerators
Need a diagram of Amana top freezer refrigerator model #ATB2132ARW My fridge has a clogged drain tube, but I can't locate the drain.
I can't find a diagram but have a different model Amana. The drain tube on mine was located just above the drip pan under the refrigerator. It was a soft plastic/rubber and had become clogged due to something sticky that stuck it together. Caused the freezer water to back up and after cleaning the tube, I had to defrost the refrigerator completely to melt the ice blocking the tube at th top (in the freezer). Sorry I can't help with more info.
Jul 30, 2011 | Amana ATB2132AR Top Freezer Refrigerator
Freezer was working but there was no cooling in the rest of the Fridge.Technicians refilled Gas and also replaced Thermostat.While compressor on,there was a thick ice deposition on the return pipe of the...
You got suckered by the sounds of it.... if your freezer is working your fridge is fine as far as gas charge goes.... thermostat MAY have been faulty but I doubt it.... Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Electrolux Refrigerators
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
I'm trying to find an inside diagram for my fridge FPE21TMW1. I believe the drain tube is clogged and I need to access it. Not the freezer but behind the meat drawer. Thanks g
Wont get much info there.(manual). Suggest you defrost fridge overnight then locate the drain tube behind the fridge on top of the compressor. Blow into the pipe aggressively until blockage is clear. When clear, switch back on and presto.
Aug 04, 2010 | Frigidaire Refrigerators
Every time my Frigidaire Model number frs26znh defrosts, water runs out of fridge door. of course, the pan in bottom of fridge is full of ice. water has not been connected for 6 weeks
Your Defrost drain Plug is clogged or kinked.
Check the tube from the freezer to the fridge, make sure it's connected, then pull out your drawers in the bottom of the fridge and clear your drain hole..
Mar 11, 2010 | Refrigerators
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
Sep 21, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
WATER AT BOTTOM OF FREEZER
Maybe when the meltdown occured a popcycle wrapper went down the drain tube and now the defrost water has nowhere to go, so it form an ice skating ring? Just a guess.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
