Lg wt5101hw washing machine will not come on
My lg washing machine will not come on at all. I've checked the electrical outlet and the machine is getting continuity. What could cause this to happen?
  • Washing Mach... Master
  • 744 Answers
You might have a problem with the door lock this might help you
Posted on Jul 22, 2013
BIKER T
  • 909 Answers
SOURCE: AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Posted on Oct 24, 2007
  • 135 Answers
SOURCE: Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
Posted on Nov 11, 2008
  • 57 Answers
SOURCE: i have a lg fully automatic washing machine
highten your wastepipe to just below lid level
Posted on Jun 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Elite Oasis He top load washing machine won't start
Tech Sheet
Posted on Mar 02, 2010
  • 33 Answers
SOURCE: My washing stopped working mid cycle. I checked
the timer is probably sticking (needs replacement) or lid safety switch stuck open. try restarting the load and if stops at the same place it is the timer unit, if it fills up with water and than stops - lid switch.
Posted on Mar 29, 2010
LG WT5101HW - Machine won't turn on. Just plays the tune softly when pressing power button. Also, machine have not been draining properly lately. Turns off by itself mid-drain with DR error code.
DR is a drain error. Have a look to see if the drain filter is blocked (if fitted) or if there is an obstruction or blockage in the pump or drain hose. If it cant pump out, the machine will stop during the cycle.
Mar 29, 2016 | LG Washing Machines
Hot wash does not work
Check filter in hose at tap end, if if the hoses screw onto back of machine, check the filter inside valve. Check hot water valve, it may be burnt out.
Mar 16, 2015 | LG WT5101HW Top Load Washers
I replaced the door seal on a Whirlpool duet ht washer and now it won't power up. I've checked all the connections and they appear to be tight. Any ideas?
I have one idea. Could the new door seal be preventing the latch interlock from functioning to allow the machine to start?
Apr 17, 2013 | Whirlpool Washing Machines
Lg top loader model wt5101hw will not drain checked drain line its good can i acess pump without taking machine apart? Anything else I can do is it possible to check pump to see if its clogged or damaged.
Doug-
Exact model, same problem here. Purchased March 2011. I was also getting error code "OE". Sears repair came today, and the water pump impeller was jammed.
He took the drain hose off the back (Watch out, water drained all over from water outlet) and stuck his finger in the water outlet. By spinning the impeller backwards and then forwards, he was able to dislodge whatever was clogging it.
Repair would have been around $170.00 if it wasn't warranty repair.
Hope this helps.
Aug 28, 2011 | Washing Machines
Hi I've got Washing Machine LG WD-8023FB front load, and SE or 5E alarm is on and machine is not working. What is that alarm for?
the alarm is indicating that the machine is not working that u should restart it or better still u check the mabual for p[roper operation
Jun 24, 2011 | LG Washing Machines
Water can't out from macshine went i want to wash
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Jun 21, 2011 | LG WFT1071TP Top Load Washer
My LG washing machine is dead. It is in my summer home and it worked before we left. The electric outlet is fine and the water supply ok. What could be wrong? Is there a fuse somewhere in the machine...
The control board is probably dead and there is no serviceable parts. There is a fuse in the board but it's encased in acrylic for moisture protection. You will have to order a replacement control board. Good luck.
Jun 17, 2011 | LG Dishwashers
LG Tromm washer powers on but turns off a second or two later. I don't see any error code since it turns off right awat. What can be the problem?
Try using another outlet. Connect an extension cord to another outlet away from the room you are in and see if that will resolve the issue. If it does, you will need to call an electrician to resolve the electrical outlet problem. If the machine continues to shut off, you will need to have the control board on the washer replaced.
Good luck
Jun 16, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg front loader washing machine would not start at all ! it seems like there's no power at all ! what should i do ?
check power at wall outlet us lamp to test for power
check power cord look for broken or loose finger in plug
Jun 09, 2011 | LG Washing Machines
MY WHIRLPOOL FRONT LOADER WASHER JUST QUIT WORKING. IT HAS LOST ALL POWER. THE DOOR WILL NOT EVEN OPEN. PLEASE HELP?
I've worked on similar models with all manner of problems. Try unplugging the machine from the electrical outlet for about 30 seconds then, plug it back in. This will "re-boot" the control board. If it doesn't work, I'd say the control board is bad.
May 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
