Question about Tower Aloha Breeze Fan
5545 the gear that makes the fan rotate stopped working is it worth trying to fix?
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
I have a 10 yr old Maytag MTB2156GE, it has been making intermittent loud cracking noises for the last week or so, came home today it has stopped working. Can it be fixed? Is it worth fixing?
sounds like the condenser fan motor is bad check in the bottem back of the unit if the fan works if not replacing it is worth on a 10 yr old machine
Sep 02, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My PC is not starting what is problem.
first make sure your ac cable is working well, then try to check the power supply of your computer if the fan rotates every time you hit the power button of your cpu, if not then change your power supply. if it fan rotates and stops, try to used another power supply if fan rotates and still won't display open up your cpu try to check if the fan over the processor will rotate and still don't recieve display. try to remove the video card and memory and clean it and re insert it. if still don't work. you got your motherboard defective.
Jul 10, 2011 | Intel SRMK2 Motherboard
My lasko fan stopped blowing air
The rotation gears have gotten clogged up, take it apart and put some grease or oil in the rotation parts/gears and work it in until it spins freely. Will work like a charge afterward. I had to do it once myself already.
Sep 24, 2010 | Lasko 2530 Elite WindTower Fan
Oscillating table fan makes banging noise when rotating
mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
The fan probably needs to be oiled? just stops
Does it slow down and stop after it has been running a little while (having had a chance to warm up?) Try this simple test with the fan cool and warmed up--- With the switch off, gently rotate the fan by hand. It should rotate very easily, and should coast to a stop not too abruptly. It should be about as free, and coast not quite as long, as the front wheel of a bicycle in good repair held off the ground. If it doesn't rotate freely, then yes, it needs oil. You might be able to get some oil on the bottom bearing without disassembly, so that's worth a try, especially if the fan is harder to turn warm than cool. If it's the same warm and cool, there's a good chance that there is hair wrapped around the shaft, and you will probably have to disassemble it to remove that - and while you are at it you can oil the top bearing. If it DOES rotate freely by hand, then you have a problem with the motor or the speed control, which is a whole other story.
Feb 24, 2010 | Hunter 20404 The Bayport Bright Brass...
Mitsubishi ts-5545, Black screen and Heart beat
A couple of things:
1) Either a bad power supply or a flyback 'supplies the high voltage to the 3 CRT's' .
2) The HOT 'High Output Transistor' is gone bad or the leads 'solder joints' have cracked and are not making a good connection.
time to get it into the shop or have a tech come to your residence to look at it.
Good possibility of getting it fixed.
A/V Media Guy
Nov 22, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Ice dispenser not working, temperature display off then on
If you pull out the collecor of ice can you then hear and see rotater arm rotating in the back of freezer. If not you need to remove panel and check for voltage at notor and inspect motor.
If you have 120vac and no motion you'll need to replace motor. We have them same day shipping 704-819-6657
Mar 14, 2009 | GE Profile¿ Arctica® Energy...
1 and 4 fan problem
This might happen when it detects a non-functioning fan (to preserve all other components).
We've had the same problem on one of our server, one fan wouldn't start (needed more current to start it)
We had to replace the motherboard on server to make it work, since this one got it power from the MB.
A temporarily fix was: Pop fan 4 out, give it a push so it rotated and quickly insert it before it stopped, hope it won't be stopping until you receive a new motherboard.
Sep 03, 2008 | HP Compaq ProLiant DL380 G3 Server
Tower Aloha Breeze Fan Logo
20 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
